hi, i have a damage ecu from crafter with engine 2.0 TDI 140HP, i get a similar ecu but is from a seat 1.6TDI, its possible convert the 1.6TDI on the 2.0TDI?
on label i see same HW
regards
regards
If hardware it is compatible , normaly yes without problems. Adapt immo and make update with sw upgrade that you needed
File Service ----- Custom Files ------ DPF / SCR / EGR / TVA / Stage ...... Immo / Airbag ETC
Manual File Service WITHOUT prepaid
hi, have try make online immo adpted but get error, can help?
Then I think the ecu it is not compatible . You must to bus same part number
clone ecu by boot will work?
regards
What tool can clone this ecu ?
Flash right Pdc and adapt whit Odis or Immo off
i can do no problem with galletto if your ecus are compability
no tool can clone this ecu for the moment . Only solution it is to find the rigth ecu (compatible ) and adapt online.
