Results 1 to 7 of 7
    Default Opel Corsa C BCM LOCKED !
    Hi, i've a problem with my corsa C '06 engine cod. Z17DTH. Body control module stopped working and accepting the security code.
    This morning i've closed the car with my remote key, and then stopped working ! Now i must open my car with the blade.
    On op-com i've seen an errore like vbus... etc, at Opel ( with official Tech2 )they tried to reflash my bcm but doesn't accept the code on my carpass, but im*o, ecu and other still working normally and accepting the code, my car starts normally.
    Now i can try only 4 times for the code, they answered i must change my bcm....
    Is there a way to unlock it ?!?
    The error ....
    Keyword #2: 8F
    Normal timing parameter set.
    VIN: censored
    vehicleManufacturerECUHardwareNumber 13111111 YF
    systemSupplierECUHardwareNumber: 0014
    systemSupplierECUSoftwareNumber: 3002
    RepairShopCodeOrTesterSerialNumber: XXXXXXXXXX
    Identifier: 010F
    CalibrationDate: 20060116
    ECUInstallationDate: 0201
    Negative answer to service 0x30
    The reason is: 0x40
    downloadNotAccepted
    i've found another Bcm from a meriva.... i hope to solve..
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    i think you will need pass for meriva bcm then virgin it
    Quote Originally Posted by teerak2uk View Post
    U're right, the meriva bcm is already without code, this time i've checked very well, eheheh.
    But.... do you think i can mount and reflash with my op-com, or it's better if done by my opel dealer ??
    If i mount this blank bcm, my car starts ? I need to do 50km from my house to opel -.-
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Sure someone will correct me if i`m wrong but i think you will need usb-upa,xpro-m or similar to virginise it then i think with your original pass you can add it to your car with op-com
    The seller answered that's already virginized by local opel.. i hope is true, however thanks for software info !
    Can i try to virginize mine ? or there is the risk to lock all ?
    i've just seen prices on ebay, they are expensive for a single use... paid my 2nd hand bcm only 45 euro, when upa costs 245 euro,
    Meat-Head's Avatar
    ON TOPIC, BETTER LATE THAN NEVER:-
    Was looking at local fly fishing store and the guy behind the counter was adamant on these you lock
    with the remote, it locks out commication with the back, unlocked with remote and bingo.
