Results 1 to 5 of 5
    Jan 2016
    Default What hardware (windows or mac) to read and write 29f400 ?
    Can anyone suggest what programmer I need to read / write that chip? Cheaper option? Thanks
    sorry I mean 29f200 as in MSM 1.4
    Andrey Pribalt's Avatar
    May 2022
    Estonia
    I use it, reads and writes normally
    Willem GQ-4X + adapter,
    Jan 2016
    Same for 29f200 ? MSM 1.4 has 29f200 apparently.
    May 2022
    Estonia
    Do you want to subtract a flush from the MSM 1.4 has 29f200 block?
    You will need to desolder 29f200 from the ECU
    Jan 2016
    I want to dump my ecu. Flash to another ecu. Check if my ecu fw is corrupted.
