Results 1 to 6 of 6
Thread: Bosch ME7.4.5
    Aug 2009
    Default Bosch ME7.4.5
    Hi, i need to swap eeprom from dead ecu to new one, but where is 95320 ? on MCU side is no eeprom. on other side how to reach ?
    thx
    florinyes's Avatar
    Dec 2009
    London Middlesex
    You need to lever it carefully and with a scalpel cut the sealant. Heat the case with a heat gun so it gets softer.. Not that easy but doable.
    And yes eeprom on the opposite side of the mcu.
    Whatever seems impossible is just not yet important enough.
    Aug 2009
    Thank you very much, i finally manage to remove board. But had to desolder conector , WUF thats lot of work, Do you remove board without desoldering.?
    Regards
    florinyes's Avatar
    Dec 2009
    London Middlesex
    No need for desoldering mate. The black connectors comes out with the pcb in one go. You need to lever on the corner and then cut the glue..
    Ta
    May 2016
    why ecu was dead? pulses fail on bobine of car? thx
    i have a car with pulses fail on four cilinder and when i open the ecu it has the same colour that yours around the pins.
    CarCity's Avatar
    Nov 2016
    Inside my clothes
    eeprom virgin 95320 for 7.4.5
