Results 1 to 13 of 13
    Mar 2022
    Default Golf 4 038906019AM problem not start
    Hello everyone I have a problem with this ECU I desolder the chip 29f400BT save file do the file in VAG EDC Suite 15 only hardcut and EGR off after that I check the checksum of file correct it first with efisio not work than I use win Ols 1.500 and the problem is that the chceksum is corrected but when I write the file to the chip car not starts no glow plug I do it many times different methods and nothing work I don't now where is the problem right now , also I use a XGecu TL866II plus programmer with sop 44 adapter
    Jun 2013
    EU
    Probably bad solder job. Vag edc15 suite corrects checksums before qrite moded file to disk.
    Aug 2014
    upload both files
    Mar 2022
    Ok I do that
    raceshadow's Avatar
    Mar 2016
    Czech Republic
    Quote Originally Posted by morgano View Post
    It is the EDC15P-6.3.2 larger case ECU. Sometimes the CRC from the VAG suite and even from the old OLS did not work.
    IF I HELPED YOU, PRESS THANKS AND REPUTATION BUTTON!!!
    Mar 2022
    ok this is the file original one and my file can somone check the files?
    Mar 2022
    Quote Originally Posted by raceshadow View Post
    soo what sould i do?
    bobolin4o's Avatar
    Bulgaria, V. Tarnovo
    Quote Originally Posted by jakuber472 View Post
    Both files in your rar are the same... hard cut at 4500 rpm and egr map to 850 mg/hub... with wrong checksum!
    Where is ori file?
    Obviously i have it, but want to see what you've read from the ecu.
    Mar 2022
    here is the file that i read from ecu
    bobolin4o's Avatar
    Here is your mod, with corrected checksum with genuine, up to date WinOls
    BTW, you can use Ultimo too...
  11. The Following User Says Thank You to bobolin4o For This Useful Post:
    jakuber472 (7th October, 2023)
  12. #11
    Baddog84's Avatar
    Sep 2012
    Germany
    WinOLS 5, FGtech, Piasini, Powergate M, Byteshooter, OptiCan Dual II, EVC BDM, VCDS, BeeProg+,Ktag, Kess V3, Autotuner, Bflash
    Fileservice
    no thanks no pass
  13. The Following User Says Thank You to Baddog84 For This Useful Post:
  14. #12
    Mar 2022
    Ok thanks I will try both the file to see if it's works
  15. #13
    Klaudas1331's Avatar
    Dec 2020
    Lithuania, Kaunas
    The most easiest thing to do would be to swap the ecu to 038906019CJ, just turn off the immobiliser in that ecu and you're good to go, everything is the same, except that the 019CJ ecu is programmable via OBD port
    Custom tuning services and solutions for VAG/BMW Diesel cars.
    If my post was helpful, don't forget to press thanks!
  16. The Following User Says Thank You to Klaudas1331 For This Useful Post:
