I just wanted to inform you, that I have solved the case. The problem about getting 3rd piston cutoff valve fault code was because I connected the piston to +12V which cuts off during the cranking and then comes on ... in fact you have to connect it to the +12V which comes on when you put ignition on and stays on even when cranking ... anyways, this was only throwing out fault code and did not have any other effect and was NOT real fault.
The real problem was fuel pressure REGULATOR (not sensor) on the high pressure pump. It did not let enough pressure through when you revved the engine over 3000 rpm, so the pressure dropped (which was monitored by fuel rail pressure sensor) and the ECU shut down the engine. After replacing fuel pressure regulator on HP pump, everything works like a charm!
