Results 16 to 30 of 40
Threaded View
    Default VCDS Hex v2 clone repair (VAG) Full Package revoked license
    VCDS 22.3.1 Hex v2 clone protection MULTILANGUE (VAG) Full Package license revoked VAG Package can convert a cheap VCDS Cable to ORIGINAL VCDS Cable and can run with any VCDS software version, even the last official VCDS Computer version V21.3.0 and comes new VCDS can continue to work with its software, also with the package. It contains many other ITEMs for VAG Cars, it includes the following contents: VCDS Clone To work with devices with the latest version of VCDS software 21.3.0 or higher The descriptions of these utilities based only on the ATmega162 chip were successful.
    NEC, ARM or others are not supported! To detect if the bootloader is enabled on your current cable, run VAGCOM_HWType.exe and click the Read button. Both the computer USB port and OBD2 port (or 12V power supply) of the cable. It also shows the hardware type of the cable.
    If the tool shows that the bootloader is enabled, you can update the EEPROM using VAGCOM_EEWriteLang.exe.
    The default language is English, but includes a language available from the drop-down list below.
    The VAGCOM_EEWriteLang.exe utility. If you speak any additional special language, the execution
    The installation will be enabled for two languages: the selected language and also English.
    Install official VCDS version 17.1.3, 17.8, 18.2, 18.9, 19.6 (or latest version 22.3.1),
    Copy VCDS Lloader.exe to installed directory and shortcut on Desktop (and Start shortcut) will work each time to start VCDS Lloader.exe
    Instead of the original shortcut to VCDS .exe. VCDS .exe will be renamed VCDS .exeL. Internet connection
    It can stay ON. Antivirus, Anti-Malware or other similar software (including Windows Defender),
    Exception expansion is required to replicate the installer replica.
  2. The Following 87 Users Say Thank You to sakin For This Useful Post:
    aerojo (26th July, 2024), Alekssm (11th March, 2024), alex0082ass (5th April, 2024), Alextech (25th February, 2025), ANIS2010 (25th November, 2024), audia4awx (20th May, 2024), bigguy670 (2nd April, 2025), BigJ (31st March, 2025), bobokg1 (29th January, 2025), braeter (30th August, 2024), cetateharman (24th February, 2025), chimai2501 (17th December, 2024), crispy001 (1st April, 2025), daniersms (13th October, 2023), das ist halt so (26th January, 2025), del_trotter (5th April, 2025), dimet (10th January, 2025), dimklimenko (6th April, 2025), djsankris (6th February, 2025), donahue171 (10th December, 2024), dskoric (26th January, 2025), DutchGuyMikey (6th January, 2025), Edber (13th August, 2024), eduardoperes (27th February, 2025), elc0nd0r (11th August, 2024), elektronik25 (1st April, 2025), eric paris (21st October, 2024), guidotacco (10th January, 2025), HARLEM (27th April, 2024), hersetbacklent (29th December, 2023), Jean6marc (30th December, 2024), JohnM62 (29th January, 2025), karol123 (11th October, 2024), karter1 (20th January, 2025), Kogen11 (19th January, 2025), konstantinbga (12th January, 2025), lavoisier1965 (28th July, 2024), linkyjo91 (23rd March, 2025), Mahero (3rd April, 2025), MarcoT (18th December, 2024), martisb22 (28th October, 2024), mobi65 (24th February, 2025), nedovix (15th November, 2024), nihad69 (3rd February, 2025), NiTroPleX (28th December, 2024), ollync (14th October, 2023), patryyk (16th February, 2024), paulie22 (2nd March, 2025), Pitin (9th March, 2025), plamyk (8th April, 2025), PSAcars (18th August, 2024), psaplas (18th June, 2024), rabro (11th December, 2023), Rena713 (29th April, 2025), rennfan (10th January, 2025), rickard (4th April, 2024), Robert Style (18th October, 2023), RooiLucy (17th January, 2025), ruilouzado (20th December, 2023), sergei5005 (17th October, 2023), SerzKaos (7th March, 2025), shepard0333 (16th November, 2023), SoakLatigidVCDS (2nd December, 2023), soekris (23rd February, 2025), sstatus99 (28th April, 2024), t0yaki (8th July, 2024), viverevd (19th February, 2025), volk (29th March, 2025), xgynesis (10th July, 2024), zaki17 (1st April, 2024), zotya54 (1st March, 2025)
