Page 1 of 2 12 LastLast
Results 1 to 15 of 20
Thread: sterview 4
    Oct 2008
    Thumbs up sterview 4
    HI im new to this forum I have ordered starview 4 is there a tutorial on this box thanks
    satsmo's Avatar
    Jun 2008
    Welcome to the forum.There is a readme that comes with the firmware.
    Oct 2008
    Angry starview 4
    in the firmware there are 2 bin files which one do you choose
    THANKS
    satsmo's Avatar
    Jun 2008
    1.02 and the logo file.
    Sep 2008
    Hi Satsmo
    What is the LOGO file used for ?. It that I have never used it.
    Nov 2008
    hi there r u using the starview for cable like virgin media????
    Sep 2008
    HI
    Yes cable ( virgin media ). The setup is working fine, it was just a question. The main reason was because you cant see the EPG information which is light blue with a blue background clearly .
    Nov 2008
    ok so how do u update the firmware then?
    im wanting to buy one for myself but thinking still.
    what difference is it from the original modded ntl box???
    Sep 2008
    Quote Originally Posted by killa_k View Post
    1- copy the 2 bin files the a USB pen
    2- plug it into the box at the back
    3- turn on box and select language
    4- go down to USB and select the 1 of the .bin file then press ok, (it will then flash and restart)
    5- repeat step 4 with the other .bin file
    6- select autoscan and choose your provider
    7- press menu and enter 1570 (for hidden menu) where it says off turn it on (emu .. carnt remeber off hand)
    8- select s*y sports channel and wait for it to update info.
    enjoy! all channels unlocked
    not sure what you mean .. the difference between sf4 and sf4usb is the usb easy flash (and that you can also add a HDD)
    Nov 2008
    ok thanks so where can i download the firmware frm.
    and also does it come with the usb stick or do i have to buy one???
    thanks.
  11. #11
    Sep 2008
    you can download the firmware from this site .. look up red writings says "Downloads"
    Unfortunately you have to buy your own, there not expensive .. google is your friend.
  12. #12
    satsmo's Avatar
    Jun 2008
    Quote Originally Posted by lamby View Post
    HI
    Thats why you need to also load the logo file .
  13. #13
    Oct 2008
    Firmware is in the very first thread called sticky and you have to purchase the usb stick separately but you can buy it at the same place where you buy the box from.
    Vu+Duo,1m Dish, 3 degree monoblock (13&16e), Zone 2 dish with quad lnb,Skybox F3
  14. #14
    Sep 2008
    Yes this was the first box i have used. Followed the instructions and got all channels, I did use the first bios thought ( seemed to scan better !!! ).
  15. #15
    Nov 2008
    Hey All, Thinking of getting the starview 4 as my first box. I assume it gets all the Scrambled channels? Does it work through a multichannel line in Ireland?
