thank you so much cause you trid to help but its not to one
Can any one help with the code for the radio
Model no 22DC278/62P
TOU 516
RN 278F20022989
Product no FD0002060022989
8200 1582 346
could any one help me with my radio code for renault scenic please
the barcode is 8200300858TT760
CODE 6299...........
i lost key and want the pincode to make new one my vin is (vf1eb11186y545661 )
my car is Renault clio
Ammory, have you read topic title?? here are only RADIO CODES not immo codes, search for the good topic to get answer for your request
i dont find can u give me the like for help plz
Model no RENRDW 130-00
Y156 SECURITY
RNRD 7160014913
Product no FD0506460014913
8200497243TY156
8200 497 243
please remove,posted in wrong thread
Last edited by jamesmclean; 11th June, 2010 at 10:29 PM. Reason: posted in wrong thread
Can you please tell me the code ?
8200205833TK122
i have tried the code 5716 but didn't worked....
thank you for answer....
Your code 5716 provided for: 8200205833TK122 is correct.
There is three common reasons why this wouldn't work.
1. Wrong information provided. Usually due to a damaged label. Recheck number K122, often it is also printed elsewhere alongside the word 'security'. If its different - repost.
2. Incorrect code entry procedure. Assuming you've used the steering column controls and displayed the code, with the ignition key set to ACC (Accessory position) - press and hold the station advance button for upto 10 seconds until a beep is heard That activates the code,
3. Your radio has been re-programmed by a radio decoder to a differnet code. Here you will need to use the services of a local radio decoder to recover the code.
Hope info helps
[remember thanks button if post useful]
