I need turn on speed limitation in edc16u34.
There's no 7 and 14 channel in adaptation (login 12233). 18 channel i set from 300 to 100 and it doesn't work. I also have tried edc16calc from 300 to 100 and it doesn't work.
So... i wanted to do it in flash. I changed:
1C0CFA, 1CODOE, 1E7335 set bytes from 2 2 to 1 2 or 2 1 ( limitation in eep or flash),
1EA7B2, and this everything doesn't work. I hope that it should be done in eep but i cannot find eep with ability of change 7, 14 or 18 channel which is active and works ;/
Normally in crafter edc16cp34 i paste piece of eep with area of 7 adaptation block with needed speed and calc cks and it works.
Here's harder for me because i can't find any ecu in my workshop which has active these hgb blocks.
Please give me some advice
