Results 1 to 5 of 5
    treo's Avatar
    R
    Default Volvo V50 2.0d 2006 no engine start
    Got a 2006 volvov50 that develop immo fault due to attempted start on low battery.
    I read ecu sid803 95320 eep, Cem mc9s12 eep
    (1k79X).
    ABS ID is 000000086954
    Please help. Thanks in advance.
    V.I.P. Master of the IMMO
    lupu_sandu's Avatar
    Far far away
    Put this is ecu
  3. The Following User Says Thank You to lupu_sandu For This Useful Post:
    treo (24th October, 2023)
    treo's Avatar
    R
    Thanks Lupu Sandu,engine run ok.
    But fault code "ecm-c301 control module faulty software checksum ecm" still present.
    rafal's Avatar
    UK - PL
    Ori flash in ECU or some mode done already?
    gwiazdamb's Avatar
    Aug 2022
    PL EU
    C301 DTC standard modified flash e.g. dpf.egr etc
    DTC has no side effects but can be turned off for
    PLEASE PRESS THE " THANKS " BUTTON
