I have acquired a laptop computer from my sister and need to get into bios to check out bios. the laptop is a compaq presario 2100 is there any one out there that can help?
When you turn the laptop on press f2 and then move to security and look for password and try to remove it. If it worked hit the thanks button!
do you have manual it will tell you how to reset bios which should work but
if that does not you might need to to find or get someone to use a default
or backdoor password into the bios to get in.
Remove CMOS Battery for half hour, all setting back to normal.
Or
Google the model number, then use the JUMPER to clear cmos
I think it is very hard to remove the battery with out striping,there is a pasward cheker that can be put on usb stick then boot to that on startup i
remove the cap that covers memory and search for battery, I saw some hp and has there the battery with connector that you could disconnect....
do you remember what bios has??? (AMI or AWARD???)
if it is award, try the password AWARD_SW
there is also a big list with passwords!
I had the same problem for 2 years. None of the above suggestions helped for me, even using backdoor passwords and various password crackers. I've eventually cracked it.
Go to the link below and I'll help you out if I can. The page describes an HP BIOS but I think Compaq are the same.
if you enter the wrong code 3 times it should give you a number post it here and ill see if i can help
Have you tried the HP website for info on changing Bios passwords, i`m pretty sure there is info on how to reset your bios password.
if you can re-flash the bios from dos. that may work, you`ll have to google the info for reflashing from dos, unless you already know what`s involved. it will involve creating a dos-bootable floppy or usb stick, plus editing the bat file
and the bios loader plus the correct bios. (flashing with an incorrect Bios may brick the Laptop)
as cunny suggested using the jumper to reset the bios works a treat
but many easy methords depending on your make
heres 2 one for compaq and dell just look for your model !!
[ame=http://www.youtube.com/watch?v=hx5HBHgv8T8&feature=fvsr]YouTube - dell d610 bios password unlock recovery www.laptop-password.com[/ame]
[ame=http://www.youtube.com/watch?v=US306Sxt090]YouTube - How to reset bios password[/ame]
Qualified Jedi Master
Virgin VBox
x2 PS3 JB FW 3.55
X2 Wii 4.2E soft modded
4x DM500S + JADE PLI
Openbox HD S9 & S10
DM800 PVR + BLACKHOLE
Dedicated Linux Debian Server
1.2M Dish Sky UK, Viasat, Sky IT ,JSC ,Tring+ Cards
90cm Fortec Star Motorized Dish
Virgin 50mb Fibre Optic Broadband
Xbox 360 Samsung LT 2.0.1 No AP25 + Liton LT 2.0
Microsoft Approved and Certified OEM System Builder
Subaru Impreza GB270 Owner
http://online-console.com
remove battery will reset cmos
