Results 1 to 5 of 5
    Junior Member popmpas's Avatar
    Feb 2018
    Default kess and scanmatik read difference
    Hi.
    I made a read from sid303 ecu with kess and scanmatik2 pro(pcmflash)
    but in hex compare do not match the codes
    can somebody explain it?
    Aug 2023
    Germany
    Quote Originally Posted by popmpas View Post
    Hi.
    readout can be different from tool to tool. One tool read more, the other read less. I think that you also dont correct the offset. Anyway, when you compare them correct, all maps should be the same.
    File Service Available:
    Stage 1/2/3
    Gearbox Tunes
    P&B on driving modes/AC
    SCR DPF EGR OFF
    Many tunes developed on own Dyno
    Feb 2018
    can i flash with scanmatik wich is readed by kess?
    Stelaras26's Avatar
    Nov 2017
    Skyrim
    I would not suggest
    except if files are mostly similar and same size
    If i Helped you,use thanks and rep button to thank me back
  5. The Following User Says Thank You to Stelaras26 For This Useful Post:
    popmpas (3rd November, 2023)
    Dec 2020
    Finland
    Usually prefer to write with same tool that you read it out..
    If i helped,give it out.. some thanks and rep and were even
  7. The Following User Says Thank You to Make80 For This Useful Post:
