Results 1 to 14 of 14
Thread: Help required
    Nov 2023
    Default Help required
    So long story short, bought an used xsara picasso 1.6 hdi 2009 ,car was a non starter, had to rebuild entire engine , now car doesnt wants to start , ecu came with immo off, but bsi still locks it and no start , ecu clearly came from another car , so i tought ill ask you guys for help, ive managed to read epprom using upa programmer , is there anything i can do to sort this thing out, so far ive just used immo file that came with second hand ecu, below is original ecu (with immo)dump and some pictures from lexia
    Nov 2023
    Hello, i can’t help with this but last week i had a problem with one xsara picassa who didn’t want to start and these cars are apparently having same problem, i started the car by bringing a cable of ground to the body of the ecu
    gwiazdamb's Avatar
    Aug 2022
    PL EU
    Quote Originally Posted by Victorzerk View Post
    Immo is disabled in your file
    If immo is turned off in the ECU, the BSI status does not matter
    The ECU should start the engine
    I suggest checking the DTCs in the engine ECU, especially the actual values
    In particular, focus on parameters such as immo status and engine speed. fuel pressure etc
    PLEASE PRESS THE " THANKS " BUTTON
    Dec 2022
    but on real data should be write ''engine ecu locked'' NO?
  5. The Following User Says Thank You to antonis132 For This Useful Post:
    Victorzerk (11th November, 2023)
  6. #5
    Dec 2022
    Could you try write this file and inform me results?
  7. #6
    Nov 2023
    Quote Originally Posted by antonis132 View Post
    Will try asap and report, i thought maybe im missing a telecodification on bsi or ecu with lexia, its driving me crazy not be able to sort this thing out, thanks for the reply
  8. #7
    Nov 2023
    Quote Originally Posted by gwiazdamb View Post
    There are only egr related dtc's at ecu , fuel pressure is somewhere arround 320 bars, engine speed is 94 revs (engine rotates only when cranking) and immo starus shows no errors, thats why im thinking bsi is the culprit
  9. #8
    fuzz1's Avatar
    Jul 2019
    If immo is off maybe you ensure that it's in park and supply current directly to the starter. Have you tried that? What happens when you try that?
  10. #9
    Nov 2023
    Quote Originally Posted by fuzz1 View Post
    Haven't tried that as engine cranks, will also try to start it with spray silicone, will post results tomorrow
  11. #10
    Mar 2020
    in the field
    Use the LED indicator and connect to the injector cube, check if there are voltage pulses when turning the engine
    If I helped, please, use magic buttons reputation+thanks.
  12. #11
    Nov 2023
    Hi, sry for the late response, no joy, car acts the same crank no start , on the side note ive noticed ecu is actually for a berlingo, same engine tho, tomorrow will try to program new virgin transponder , will try to read pin code from bsi , dunno if i can do that with upa programmer, will post results
  13. #12
    Nov 2023
    Quote Originally Posted by pawl View Post
    Was the second or third thing sorted out, no pulse on inyectors
  14. #13
    mexanico1971's Avatar
    portugal
    Get a multimeter / oscilloscope , check BSM outs , Crankshaft signal , ecu voltages
    My work is my life ART TECH GARAGE
  15. #14
    Mar 2020
    in the field
    The synchronization of the shaft and camshaft sensors still needs to be checked
