Results 1 to 5 of 5
    Apr 2009
    Default DM800 DiseqC switch inline amp
    DM800 4 way DiseqC switch 28/19/16/13 east
    all switch ok all SD work fine
    but about 5 HD channels glitch on 28 east
    so i put in a 20db inline amp HD channels now fine no glitch
    all channels on 28/19/16/ fine
    now i get no signal on most of 13 east SD and HD
    so i take amp off
    all channels on all sats fine apart from the 5 HD channels that glitch on 28 east
    and with inline amp signal on all sats goes lower not higher
    amp is on the right way
    any help appreciated
    Apr 2009
    problem solved
    the amp that was giving me problems was a
    Gecen In-line Amp 20Db
    pile o crap
    change to this one
    In-Line Signal Amplifier Sky Satellite Booster + 2F's on eBay (end time 14-Apr-10 10:33:06 BST)
    all ok no
    glitching and all sats switch no loss of any channels
    Nov 2010
    I have the amp you suggest but it's giving me similar problems: no signal on 28.2 east. Any help? thanks
    P.S. What kind of LNB do you have?
    Sep 2011
    Try changing your patch cable, that might be faulty which is causing the lower signal.
    Apr 2009
    @Chris13
    i posted this 18 months ago
    i bought a different amp and it sorted it
    problem solved
