Results 1 to 13 of 13
    Jul 2015
    Default Delphi DS1OO RED LIGHT
    Hello, I have a problem with my device. It was running the 2015 update. I downloaded the 2020 update, activated the program, and opened it. Everything was fine.:larmes de joie: After that, I connected the Delphi DS1OO and updated it, and it started flashing red. Then the update was successful, but my device remained stuck on solid red lights and the appearance of no VCI.:grincheux:
    Is there a solution because I am sure I made a mistake in updating
    Aug 2020
    Quote Originally Posted by joji maroc View Post
    Use WOW to recover the firmware. It could not have finished if it is still flashing red. If you are using double pcb then it will not work passed 2017 anyway regardless of the software or firmware you use on it. If it is single pcb then use 3201 firmware
    HaynesPro 2025 online + AC/ Delphi 2022.02a available, message for where to get them!
    Jul 2015
    Merci pour votre réponse, mais j'ai essayé d'installer WOW The program does not open
    Aug 2020
    Thank you for your answer, but I tried to install WOW but it does not work
    So you did not get it installed?
    Jul 2015
    Non, monsieur, je vais le réinstaller
    Aug 2020
    Reinstall it and update the firmware by usb cable and it should recover the vci
    Jul 2015
    Ok sir, I will try the method and tell you the result
    Jul 2015
    Hello, after installing Wow Snowbar and connecting it to the Delphi device,
    how can I update the device so that it does not remain stuck on the red light?
    Jul 2015
    i updat by wow but not work
    Aug 2020
    Ok, put that one in the bin and buy a new one
    Jul 2015
    OK:décapité::décapité::décapité:
    Aug 2020
    j'ai mis à jour par wow mais ça ne marche pas
    I know, you already said. Buy a new one...
  13. #13
    Jul 2015
    Eh bien, mon ami, que me conseillez-vous concernant le scanner Delphi ?
    Quel modèle est le meilleur ?
