Results 1 to 4 of 4
    Sep 2016
    Default Autel maxicheck mx808
    Hey there peace upon you,Am new in here,
    Manufacturer Autel
    Model Maxicheck MX808 Automotive scanner tablet
    Firmware Version 1.0
    I forget screen lock password I communicated with
    http://www.autel.com/ Autel Tech Support
    Sent me flash file and step how to flash
    But not successful, while I starte ADB.exe
    Error unauthorized device,for reference
    Attached error screen shot,
    so please
    assistance to resolve the issue.
    With Regards
    Feb 2010
    Ihave sam problème with im ihave password and tell me is wrong autel failed if you resolve tell me if you need help
    Feb 2025
    united kingdom
    Hey, so it looks like you're stuck with the "unauthorized device" issue. First things first, make sure your ADB drivers are up to date. Sometimes it's just the drivers messing things up. You might also want to try enabling Developer Mode on the tablet, though I know that's tough if the screen's locked. Another thing that could help is making sure USB Debugging is on – again, if you can access the settings. If not, try holding down the power button to reboot it in recovery mode, see if that helps with flashing. Honestly, sometimes these things need a bit of trial and error. If nothing works, maybe try reaching out to Autel tech support again with the exact error code you’re seeing. Fingers crossed!
    Mar 2013
    UK
    First need to using Windows 7 not 10 or 11 poor comunication !
