Hello a custmer have clio 4 after dead battery and card wont to start car i ask the best way to solve this problem . Thank you.
drupal (22nd November, 2023)
What's Renault Asus account?
Most likely HFM module data got corrupt. Solution is very easy, just reprogram HFM by Clip Online.
drupal (24th November, 2023)
Renault Asus is the Renualt online portal for reprogramming modules....
if you have a renault clip you can register on the portal, purchase the physical token and then, depending on what you need, purchase the service....
I have a clip but not the token yet...
in this case you can find someone with access to the portal and get help remotely using your clip.....
[SIZE=3][I][FONT=impact][COLOR=#ffd700]PUSH THANKS AND REP IF I HELPED YOU !!!!!!
I can reprogram Renault remotely if you have scanmatik 2 pro and Renault Clip software.
Ford / Linkoln / Mazda PATS remote module and keys programming service
VAG MIB1 MIB2 headunit programming, coding, maps update, language conversion
GM remote module and keys programming service
BMW module programming, coding, maps update, language conversion
drupal (4th December, 2023)
