Page 6 of 9 FirstFirst 123456789 LastLast
Results 76 to 90 of 131
  1. #76
    Aug 2024
    Default thanks
    Quote Originally Posted by Gaztoof View Post
    New 2023 improved crack for WinOLS 4.7
    This crack differs from other for the following reasons:
    - No more "Starting update..." bug!
    - No more changing windows's time / requiring a VM!
    - No more blocking every request to evc.de!
    - Unlike every single public one, NO MORE VIRUS
    - You can now finally browse the internet while having WinOLS open!
    Installation:
    1. Install WinOLS 4.7 (WinOLS4.7.4 - Native Installer.exe), then during the installation, make sure you UNTICK "Create a desktop shortcut", and at the very end untick "Launch WinOLS" !!!
    2. Go to "C:\Program Files (x86)\EVC" and delete the "WinOLS" folder.
    4. Slide the WinOLS directory from the this archive into "C:\Program Files (x86)\EVC" (IF WinOLS ALREADY EXISTS THERE, DELETE IT!!)
    4. Right click the .exe file "C:\Program Files (x86)\EVC\WinOLS\OLS3.exe", go to Properties, go to Compatibility, and enable "Run this program as an administrator".
    5. You can now send a shortcut of OLS3.exe anywhere on your computer to easily start WinOLS
    6. Install WinOLS 5 test version (WinOLS_Testversion.64Bit.exe) normally
    7. Launch WinOLS 5 test version
    8. Click "Choose different path..." and select the directory "C:/Users/Public/Evc/WinOLS" as shown
    Attachment 1031112
    FINISHED! YOU CAN NOW USE WINOLS 5 AND THE CRACK!
    Unfortunately, this crack still has a few bugs, including:
    - The auto-scroll, which is easy to stop
    - The ALT + CONTROL not working properly (seeing maps directly in HexDump)
    - Project creation is impossible with the crack (but easy on WINOLS 5)
    The solution to all these problems is WINOLS 5!
    The best use of this crack is by combining the latest WinOLS 5 and this crack! FOR FREE!
    To create a new project, discover maps, and make modifications, use WinOLS 5 because it is very smooth, practical, and visually pleasing!
    Once your mapping is finished, close the project on WINOLS 5 (otherwise it will be locked), go to WinOLS 4.7 to make the checksum corrections and export the .bin! Or use the plugins (for example, the DAMOS IMPORT).
    WinOLS 5 runs without BUGS! So I highly recommend using it to discover maps, navigate in HexDump, etc...
    Be careful, only one instance of WinOLS can use a project simultaneously, so to switch between WinOLS 5 and WinOLS 4.7 on a single project, make sure to close it before opening it in the other version
    Please, note that to create a new project and import a binary file, you have to do the following:
    1. Launch WinOLS5 Test Version and create a new project and import your file and everything as you want to then close WinOLS 5.
    2. Launch WinOLS 4.7 crack, click Open, and the project should be there.
    And if you want to search for maps using the hex dump, and alt left click, do it directly in WinOLS5 !!
    /!\ MAKE SURE YOU LAUNCH THE CRACK AS ADMINISTRATOR!!!
    Obviously, if you do not install according to the above instruction lists, the crack will NOT WORK.
    Credits go to: t.me/Gaztoof
    Feel free to donate to motivate me to crack more software:
    BTC: bc1q6zd8m662vvtrmuk8cmgctl7f7nzcqajs2sh0yv
    ETH: 0x65c93c24d47dF946997b29508D58fb7AF622E500
    BCH: qpspqu33hjt47ppwdxa04gzrgfjn78qnv5h4zpwhld
    If you have a recent version of WinOLS, please contact me so I can try to crack it without leaving your customer id's in the crack!
    DOWNLOAD LINKS ARE ATTACHED TO THIS THREAD
    Also, please note the correct link is the gofile one. You can ignore the other one as he expired.
    thankssssssssssssssssss
  2. #77
    Aug 2024
    Default Thank´s
    Thank´s for the link!
    Installation:
    Attachment 1031112
  3. #78
    Sep 2024
    thanks for your work!
  4. #79
    Sep 2024
    hello Can I get the link please
  5. The Following User Says Thank You to farhadmahmood For This Useful Post:
    Itagent (24th September, 2024)
  6. #80
    Oct 2024
    errors happens trying to fix it
  7. #81
    Oct 2024
    Default link
    i dont know how to get the link trying again
  8. #82
    Jan 2024
    i will pray for you if it works
    thank you
  9. #83
    Oct 2024
    Espaņa
    hola, te doy las gracias aun que no pueda bajarlo, gracias por compartir
  10. #84
    Mar 2019
    i don"t open file, sir
  11. #85
    Oct 2024
    thanks a lot mate.
  12. #86
    Feb 2021
    Thank you for this kind sir.
  13. #87
    Nov 2024
    Hi i can't download idk why
  14. #88
    Nov 2024
    Thanks! works
  15. #89
    Nov 2024
    Works great ��
  16. #90
    Jun 2021
    Can't open the project created with winols 5, it says 1 project was ignored when opening the projects menu from winols 4.7.
    Even if I change directory to WinOLS, it still creates projects in WinOLS Demo.
    Nvm, I changed directory in WinOLS 4.7 to Winols Demo but I reinstalled the included winols 5 from the rar instead of the latest from the evc website and now it works.
