Good evening, everyone. I encountered an ABS coding issue with my car. I attempted to replace the digital cockpit with another one, and now the ABS coding is null. The entire code is showing only zeros. Please help me, and thank you all in advance.i have mk7.5 with 000 coding i need help for the abs coding
golf 7 12-2017. version europe
WVWZZZAUZJW106918
diesel 110kw. 150ch
FWD
manual
Vendredi,24,November,2023,21:00:49:19766
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 11 x64
VCDS Version: 23.11.0.0 (x64) HEX-NET2 CB: 0.4643.5
Data version: 20231027 DS351.0
www.Ross-Tech.com
VIN: WVWZZZAUZJW106918 License Plate:
Mileage: 205421km Repair Order:
Type chassis: AU-VW37 (3Q0)
Scanner: 01 03 05 08 09 10 13 15 16 17 19 29 2B 39 42 44 4B 52 5F D6
D7
VIN: WVWZZZAUZJW106918 KilomÈtrage: 205421km
01-Moteur -- Etat: DÈfaut 0010
03-Freins ABS -- Etat: DÈfaut 0010
05-Autor. dÈmarrage -- Etat: OK 0000
08-Climatronic -- Etat: OK 0000
09-Centrale Elec. -- Etat: OK 0000
10-Assistance stationnt -- Etat: DÈfaut 0010
13-RÈgulation dist. -- Etat: DÈfaut 0010
15-Airbags -- Etat: DÈfaut 0010
16-Volant multifonct. -- Etat: OK 0000
17-Instruments -- Etat: DÈfaut 0010
19-Gateway CAN -- Etat: OK 0000
29-Feu gauche -- Etat: OK 0000
2B-Verr. Col. Direct. -- Etat: OK 0000
39-Feu droit -- Etat: OK 0000
42-Porte conducteur -- Etat: OK 0000
44-Direction assistÈe -- Etat: OK 0000
4B-Module Multifonc. -- Etat: OK 0000
52-Porte passager -- Etat: OK 0000
5F-Electr. d'informat. -- Etat: DÈfaut 0010
D6-Ctrl feu gauche 2 -- Etat: OK 0000
D7-Ctrl feu droit 2 -- Etat: OK 0000
Adresse 01: Moteur (J623-DCYA) Labels:. 04L-907-309-V1.clb
No. piËce Log: 04L 906 026 HB Mat: 04L 907 309 R
PiËce: R4 2.0l TDI H24 3052
RÈvision: B5H24--- CVN: 957C7264
Codage: 01190012034405083000
No. Atelier: WSC 01357 011 00200
Jeu de donnÈes ASAM: EV_ECM20TDI01104L906026HB 004002
ROD: EV_ECM20TDI01104L906026EM_004_VW37.rod
VCID: 71BFD5D9012AE452F04-8024
VINID: 9E69EAAAA465A9A9C10062412018C3777D
1 Code dÈfaut trouvÈ:
4716 - Aucune communication avec le calculateur-Frein de stationnement Èlectrique
U0128 00 [039] - -
Non ConfirmÈ - TestÈ depuis R‡Z mÈmoire
Capture:
Etat du dÈfaut: 00000001
PrioritÈ du dÈfaut: 6
FrÈquence du dÈfaut: 1
KilomÈtrage: 205421 km
Date: 2023.11.22
Temps: 20:37:33
RÈgime moteur: 0.00 /min
Valeur de charge normÈe: 0.0 %
Vitesse du vÈhicule: 0 km/h
TempÈrature du liquide de refroidissement: 36 ∞C
TempÈrature air díadmission: 39 ∞C
Pression de l'air ambiant: 970 mbar
Tension borne 30: 11.800 V
Compteur de dÈsapprentissage selon OBD: 40
Limitation: accÈlÈrateur: 0.0 Nm
Statut CAN - calculateur du moteur-Bits 0-7: 0
RÈgulateur de vitesse: Ètat-Bits 0-7: 7
Statut CAN - calculateur de boÓte-Bits 0-7: 0
Statut CAN - calculateur de freins 1-Bits 0-7: 0
Statut CAN - calculateur de freins 2-Bits 0-7: 0
Vitesse engagÈe-Bits 0-7: 0
Tests passÈs: 0 0 0 0 1
Adresse 03: Freins ABS (J104) Labels: 5Q0-907-379-IPB-V1.clb
No. piËce Log: 5Q0 614 517 CE Mat: 5Q0 614 517 AC
PiËce: ESC H25 0413
RÈvision: 00000000 No. de sÈrie: 52517000002201
Codage: 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000
No. Atelier: WSC 00000 000 00000
Jeu de donnÈes ASAM: EV_Brake1UDSContiMK100IPB 036010
ROD: EV_Brake1UDSContiMK100IPB_036_VW37.rod
VCID: 76B5E6C56844C36A256-8022
10 Codes dÈfaut trouvÈs:
0195 - Calculateur non codÈ
U1013 00 [137] - -
[ECU marked as Not Configured because vehicle ID is invalid]
TÈmoin allumÈ - ConfirmÈ - TestÈ depuis R‡Z mÈmoire
Capture:
PrioritÈ du dÈfaut: 1
Compteur de RAZ: 128
Date: 2023.11.22
Temps: 20:37:34
0212 - Capteur d'accÈlÈration longitudinale
C1017 54 [137] - Calibration manquante
Capture:
Date: 2023.11.22
Temps: 20:37:34
0270 - Transmetteur d'accÈlÈration transversale
C1079 54 [137] - Calibration manquante
Capture:
Date: 2023.11.22
Temps: 20:37:34
0279 - Transmetteur 1 de pression de freinage
C107A 54 [137] - Calibration manquante
Capture:
Date: 2023.11.22
Temps: 20:37:34
0295 - Transmetteur díangle de braquage
B1168 54 [137] - Calibration manquante
Capture:
Date: 2023.11.22
Temps: 20:37:34
8299 - Bus de donnÈes
U1121 00 [009] - message manquant
[FCAN: Anhaenger_01_alt veraltet bit is set]
Capture:
PrioritÈ du dÈfaut: 3
FrÈquence du dÈfaut: 2
Date: 2023.11.22
Temps: 20:37:34
8306 - Bus de donnÈes
U1122 00 [137] - message non plausible
[FCAN: Unplausible VIN number]
Capture:
PrioritÈ du dÈfaut: 2
Date: 2023.11.22
Temps: 20:37:39
8308 - Calculateur mal codÈ
U1014 00 [009] - -
[FCAN: StartStop not coded but MO_StartStopp_Status not equal 0]
Capture:
Date: 2023.11.22
Temps: 20:37:34
8314 - ContrÙler code/variantes des Calculateur ds la ligne de transmission
P1647 00 [009] - -
[FCAN: Coding of ESP and TSK does not fit together]
Capture:
Date: 2023.11.22
Temps: 20:37:36
32848 - Calculateur de frein de stationnement ÈlectromÈcanique
C10E2 F1 [137] - Boutons/Moteurs dÈtectÈs
Capture:
Date: 2023.11.22
Temps: 20:37:34
Adresse 05: Autor. dÈmarrage (J518) Labels:| 5Q0-959-435.clb
No. piËce Log: 5Q0 959 435 C Mat: 5Q0 959 435
PiËce: VWKESSYMQB 021 0803
RÈvision: 00021000 No. de sÈrie: 0457280264 DonnÈes UDS:: V03935252RD 0001
Codage: 032C0C
Jeu de donnÈes ASAM: EV_KessyHellaMQBAB 002020
ROD: EV_KessyHellaMQBAB_002.rod
VCID: 3C2134ED16E8593A132-8068
Aucun code dÈfaut trouvÈ.
Adresse 08: Climatronic (J255) Labels:| 5G0-907-044.clb
No. piËce Log: 5G0 907 044 CE Mat: 5G0 907 044 CE
PiËce: Climatronic H04 1801
RÈvision: 00001K08
Codage: 00020114202110011005000000101022
Jeu de donnÈes ASAM: EV_ACClimaBHBVW37X 006145
ROD: EV_ACClimaBHBVW37X_006_VW37.rod
VCID: 6C81C4AD260809BAC32-8038
Calculateur de soufflante d'air frais (avant):
Transmetteur de pression du fluide frigorigËne/de tempÈrature de fluide frigorigËne:
Capteur de qualitÈ d'air:
Adresse 09: Centrale Elec. (J519) Labels:. 5Q0-937-08X-V2.clb
No. piËce Log: 5Q0 937 084 CP Mat: 5Q0 937 084 CF
PiËce: BCM MQBAB M+ H36 0253
No. de sÈrie: 01001728200693 DonnÈes UDS:: V03935271WR 0001
Jeu de donnÈes ASAM: EV_BCMMQB 018001
ROD: EV_BCMBOSCH_018.rod
VCID: 0849983D12B0C59A47A-805C
Calculateur de moteur díessuie-glace:
Sous-systËme 1 - No. piËce Log: 5G1 955 119 A Mat: 5G1 955 119 A Labels: 5QX-955-119-V1.CLB
PiËce: WWS 170921 043 0551
No. de sÈrie: 170928061443
Codage: 0E4DDD
DÈtecteur de pluie et de luminositÈ:
Sous-systËme 2 - No. piËce Log: 5Q0 955 547 B Mat: 5Q0 955 547 B Labels: 5Q0-955-547.CLB
PiËce: RLHS 047 0105
No. de sÈrie: S8Y17M10D12H17M43S28
Codage: 00A8DD
Calculateur díouverture/fermeture de toit coulissant:
Sous-systËme 3 - No. piËce Log: 8V3 959 591 A Mat: 8V3 959 591 A
PiËce: J245 PS73.404 H04 0005
No. de sÈrie: 0000FST001TA1JO00000
Codage: 181901
Adresse 10: Assistance stationnt (J446) Labels:| 5Q0-919-294.clb
No. piËce Log: 5QA 919 294 B Mat: 5QA 919 294
PiËce: PDC 8 KanalH07 0044
No. de sÈrie: 000308418617285 DonnÈes UDS:: V03935270DP 0001
Codage: 0471151801
Jeu de donnÈes ASAM: EV_EPHVA18AU3700000 009035
ROD: EV_EPHVA18AU3700000_009_VW37.rod
VCID: 4BC367314346EE82AA8-801E
2 Codes dÈfaut trouvÈs:
12658704 - Bus de donnÈes
[Steuerger‰t f¸r elektrische Park-/Handbremse-J540 - EPB_01 - kein Signal/keine Kommunikation]
Capture:
Date: 2023.11.22
Temps: 20:37:33
13637426 - Bus de donnÈes
U1123 00 [009] - valeur de dÈfaut reÁue
[ESP - ESP_21.ESP_Systemstatus - Fehlerspeicher auslesen]
Capture:
Date: 2023.11.22
Temps: 20:37:33
Adresse 13: RÈgulation dist. (J428) Labels:| 5Q0-907-572-V2.clb
No. piËce Log: 5Q0 907 572 J Mat: 3QF 907 572
PiËce: ACC BOSCH MQB H10 0654
DonnÈes UDS:: V03935259QS 0001
Codage: 2B00600151FFC728949C810560400600000000000000000000
Jeu de donnÈes ASAM: EV_ACCBOSCHVW416 002006
ROD: EV_ACCBOSCHVW416_002_VW37.rod
VCID: 3E253EE500F44B2A3D6-806A
5 Codes dÈfaut trouvÈs:
0828 - Bus de donnÈes
[FAULT_EGO_FZG_GUETE_GIERRATE_SENSOR_DEFECT]
Capture:
PrioritÈ du dÈfaut: 4
Date: 2023.11.22
Temps: 20:37:34
TempÈrature calculateur: 11 ∞C
Tension borne 15: 11.8 V
Velocity_vehicle_reference: 0.00 m/s
Longitudinal_acceleration_vehicle_reference: 0.00 m/s≤
Status_ACC_System: ACC_irreversible error
0822 - Bus de donnÈes
[FAULT_EGO_FZG_GUETE_LAENGSBESCHLEUNIGUNG_SENSOR_DE FECT]
Capture:
Date: 2023.11.22
Temps: 20:37:34
2101 - Bus de donnÈes
[FAULT_ESP_STATUS_SYSTEM]
Capture:
Date: 2023.11.22
Temps: 20:37:34
1054 - Bus de donnÈes
[FAULT_TIMEOUT_EPB_01]
Capture:
Date: 2023.11.22
Temps: 20:37:34
2068 - Bus de donnÈes
[FAULT_TSK_IRREV_FAIL]
Capture:
Date: 2023.11.22
Temps: 20:37:34
Adresse 15: Airbags (J234) Labels:| 5Q0-959-655.clb
No. piËce Log: 5Q0 959 655 BJ Mat: 5Q0 959 655 BJ
PiËce: AirbagVW21 005 0336
No. de sÈrie: 003VWR3G042W DonnÈes UDS:: V03935259SM 0001
Codage: 98CCC000000000005C0000CF000800000065
Jeu de donnÈes ASAM: EV_AirbaVW20SMEVW37X 002158
ROD: EV_AirbaVW20SMEVW37X_VW37.rod
VCID: 094F9D3909BABC92584-805C
RÈtracteur de ceinture gauche:
Sous-systËme 1 - No. piËce Log: 5G0 980 945 B Mat: 5G0 980 945 B
PiËce: BeltPretRevFL H37 0350
No. de sÈrie: 34169667E07101740581
Codage: 333135
RÈtracteur de ceinture droit:
Sous-systËme 2 - No. piËce Log: 5G0 980 946 B Mat: 5G0 980 946 B
PiËce: BeltPretRevFR H37 0350
No. de sÈrie: 34169668E08101740020
Codage: 333135
Capteur de collision du sac gonflable latÈral: cÙtÈ conducteur:
Sous-systËme 3 - No. piËce Log: ----------- Mat: 480 001 110 17
PiËce: SideSensor_Df 001 0887
No. de sÈrie: 35700000000F8910182G
Codage: 2D2D2D
Capteur de collision pour sac gonflable latÈral CP:
Sous-systËme 4 - No. piËce Log: ----------- Mat: 480 001 110 17
PiËce: SideSensor_Pf 001 0887
No. de sÈrie: 358000000003872C872M
Codage: 2D2D2D
Capteur de collision du sac gonflable latÈral arriËre: cÙtÈ conducteur:
Sous-systËme 5 - No. piËce Log: ----------- Mat: 480 400 610 17
PiËce: SideSensor_Dr 000 6149
No. de sÈrie: 3510001C7267FA34C147
Codage: 2D2D2D
Capteur de collision pour sac gonflable latÈral AR: CP:
Sous-systËme 6 - No. piËce Log: ----------- Mat: 480 400 610 17
PiËce: SideSensor_Pr 000 6149
No. de sÈrie: 3520001A32685243674S
Codage: 2D2D2D
Capteur de collision du sac gonflable frontal: cÙtÈ conducteur:
Sous-systËme 7 - No. piËce Log: ----------- Mat: 480 401 210 17
PiËce: FrontSensor_D 000 6149
No. de sÈrie: 3550001C72685273031R
Codage: 2D2D2D
4 Codes dÈfaut trouvÈs:
9682162 - Frein multi-collisions
B13BC F2 [137] - Pas de fonction
Capture:
Date: 2023.11.22
Temps: 20:37:33
1049093 - Bus de donnÈes
[NWD: 0x101 ESP_02 error value ESP_Querbeschleunigung]
Capture:
Date: 2023.11.22
Temps: 20:37:36
1049094 - Bus de donnÈes
[NWD: 0x101 ESP_02 error value ESP_Laengsbeschleunigung]
Capture:
Date: 2023.11.22
Temps: 20:37:37
1049095 - Bus de donnÈes
[NWD: 0x101 ESP_02 error value ESP_Gierrate]
Capture:
Date: 2023.11.22
Temps: 20:37:37
Adresse 16: Volant multifonct. (J527) Labels:| 5Q0-953-549.clb
No. piËce Log: 5Q0 953 507 HL Mat: 5Q0 953 549 E
PiËce: Lenks. Modul 003 0140
RÈvision: -------- No. de sÈrie: 10101704220906
Codage: 0400
Jeu de donnÈes ASAM: EV_SMLSKLOMQB 020002
ROD: EV_SMLSKLOMQB_020_VW37.rod
VCID: 074B9B011FAECAE24E0-8052
Adresse 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI3
No. piËce Log: 5G1 920 751 C Mat: 5G1 920 751 C
PiËce: KOMBI 302 0310
Codage: 07A429102F80000801886A011401000000000000
No. Atelier: WSC 00078 790 12345
Jeu de donnÈes ASAM: EV_DashBoardVDDMQBAB 009060
ROD: EV_DashBoardVDDMQBAB_009_VW26.rod
VCID: 2809F8BDF270E59A67A-807C
16776967 - Bus de donnÈes
[EPB_02 keine Kommunikation]
Capture:
Date: 2023.11.22
Temps: 20:37:33
16776973 - Bus de donnÈes
[RKA_01 keine Kommunikation]
Capture:
Date: 2023.11.22
Temps: 20:37:33
Adresse 19: Gateway CAN (J533) Labels:| 3Q0-907-530-V1.clb
No. piËce Log: 3Q0 907 530 G Mat: 3Q0 907 530 C
PiËce: GW MQB High 518 5304
No. de sÈrie: 03101710800621 DonnÈes UDS:: V03935266ZJ 0001
Codage: 030100045F086800FA000248080F0001000107000000000000 0000000000
GVL: 01563C0000000600400C800000004800000000000002000000 00000000000000
Jeu de donnÈes ASAM: EV_GatewNF 013023
ROD: EV_GatewNF_VW37.rod
VCID: 33331FD13BB69642C28-8066
Alternateur:
Calculateur de volant multifonction:
Sous-systËme 2 - No. piËce Log: 5G0 959 442 K Mat: 5G0 959 442 K Labels: 3C8-959-537.CLB
PiËce: E221__MFL-DC1 H17 0040
No. de sÈrie: 29170002192210067401
Codage: 2CFFFF
Calculateur de surveillance de la batterie:
Sous-systËme 3 - No. piËce Log: 5Q0 915 181 K Mat: 5Q0 915 181 K
PiËce: J367-BDMHella H10 9070
No. de sÈrie: 9509335404
Adresse 29: Feu gauche (J1018) Labels: 8V0-907-399.clb
No. piËce Log: 8V0 907 399 D Mat: 8V0 907 399 D
PiËce: LCM_MLBevoH08 0014
Jeu de donnÈes ASAM: EV_LCMLeftHELLAAU736 001012
ROD: EV_LCMLeftHELLAAU736_VW37.rod
VCID: 47CB5B015F2E0AE28E0-8012
Adresse 2B: Verr. Col. Direct. (J764) Labels:* 5Q0-905-861.clb
No. piËce Log: 5Q0 905 861 A Mat: 5Q0 905 861 A
PiËce: ELV-MQBA H01 0120
RÈvision: 00000000 No. de sÈrie: 17000290572004
Codage: 5500000000000000
Jeu de donnÈes ASAM: EV_ELVMarquMQB 004111
ROD: EV_ELVMarquMQB_004_VW37.rod
VCID: 34311CCD3EB8917ADB2-8060
Adresse 39: Feu droit (J1023) Labels: 8V0-907-399.clb
Jeu de donnÈes ASAM: EV_LCMRightHELLAAU736 001012
Adresse 42: Porte conducteur (J386) Labels:| 5QX-959-X93-42.clb
No. piËce Log: 5Q0 959 593 E Mat: 5Q0 959 593 B
PiËce: TSG FS 020 0041
No. de sÈrie: 080917EI803832 DonnÈes UDS:: V03935257JP 0001
Codage: 003B1320D000048000001000
Jeu de donnÈes ASAM: EV_DCUDriveSideEWMAXKLO 006003
ROD: EV_DCUDriveSideEWMAXCONT.rod
VCID: 43D34F116B1626C2528-8016
Calculateur de porte arriËre cÙtÈ conducteur:
Sous-systËme 1 - No. piËce Log: 5Q0 959 811 D Mat: 5Q0 959 811 D Labels: 5QX-959-81X-V1.CLB
PiËce: FOND_FHSG_DRV 006 0007
No. de sÈrie: 00000000000016705948
Codage: 110000
Adresse 44: Direction assistÈe (J500) Labels:| 5Q0-909-144.clb
No. piËce Log: 5Q0 909 144 T Mat: 5Q0 909 144 R
PiËce: EPS_MQB_ZFLS 129 1072
DonnÈes UDS:: V03935259RX 0001
Codage: 0107
Jeu de donnÈes ASAM: EV_SteerAssisMQB 013144
ROD: EV_SteerAssisMQB_013.rod
VCID: 45D75109652218F27CC-8010
Adresse 4B: Module Multifonc. (J745) Labels:| 3Q0-907-338-V1.clb
No. piËce Log: 3Q0 907 338 Mat: 3Q0 907 338
PiËce: FCM MQB Low 002 0286
No. de sÈrie: 29091710520622 DonnÈes UDS:: V03935259VB 0001
Codage: 000000050100164A00100F0102000000000000000000000000 0000000000
Jeu de donnÈes ASAM: EV_MultiModulContiVW48X 001010
ROD: EV_MultiModulContiVW48X_001.rod
VCID: 72BDDAD5042CDF4A09E-8026
Adresse 52: Porte passager (J387) Labels:| 5QX-959-X92-52.clb
No. piËce Log: 5Q0 959 592 E Mat: 5Q0 959 592 B
PiËce: TSG BFS 020 0041
No. de sÈrie: 230917EIN00279 DonnÈes UDS:: V03935267WT 0001
Codage: 003B1120DE00048000801000
Jeu de donnÈes ASAM: EV_DCUPasseSideEWMAXKLO 006003
ROD: EV_DCUPasseSideEWMAXCONT.rod
VCID: 42DD4A15740C2FCA59E-8016
Calculateur de porte arriËre cÙtÈ passager:
Sous-systËme 1 - No. piËce Log: 5Q0 959 812 D Mat: 5Q0 959 812 D Labels: 5QX-959-81X-V1.CLB
PiËce: FOND_FHSG_PSG 006 0007
No. de sÈrie: 00000000000016870520
Codage: 090000
Adresse 5F: Electr. d'informat. (J794) Labels:| 5G0-035-MIB-STD2.clb
No. piËce Log: 3Q0 035 846 B Mat: 3Q0 035 846 B
PiËce: MU-S-N-ER 851 0879
No. de sÈrie: DonnÈes UDS:: V03935262VW 0001
Codage: 02731001FF0000005111000100080A001F0500D401200100CF
Jeu de donnÈes ASAM: EV_MUStd4CDELP 001001
ROD: EV_MUStd4CDELP_VW26.rod
VCID: 303910DDCAA0AD5ABFA-8064
UnitÈ d'affichage et de commande 1 pour Èlectronique d'information:
Sous-systËme 1 - No. piËce Log: 5G6 919 605 B Mat: 5G6 919 605 B
PiËce: ABT_Std-2_Nav H50 8130
No. de sÈrie: VWZ6ZHT2711423
Support de donnÈes:
Sous-systËme 2 - No. piËce Log: 5NA 919 866 DP Mat: -----------
PiËce: ECE1 2024 --- 2110
No. de sÈrie: --------------------
7 Codes dÈfaut trouvÈs:
1544 - Calculateur dÈfectueux
B2000 45 [009] - Erreur de mÈmoire de programme
[Control module faulty: error in flash (flash programing incorrect)]
Capture:
KilomÈtrage: 203755 km
Date: 2023.10.31
Temps: 16:18:55
Tension borne 30: 12.9 V
1555 - VÈrifier la gestion de version de logiciel
B201A 00 [009] - -
[Check software version management]
Capture:
Date: 2023.11.22
Temps: 20:37:33
Tension borne 30: 11.8 V
Status_Software_Version_Management-module_name: C
1556 - Calculateur dÈfectueux
B2000 87 [009] - Message manquant
Capture:
Date: 2023.11.22
Temps: 20:37:33
Modules logiciel: Ètat-SW_Status_Consistency: 01 00 00
Modules logiciel: Ètat-SW_Status_Device: 0
0517 - Haut-parleur de graves avant droit
B1062 13 [009] - Circuit ouvert
[Tieftonlautsprecher Kanal 2: Unterbrechung (DC-Diagnose)]
Capture:
Date: 2023.11.22
Temps: 20:37:37
Tension borne 30: 11.9 V
0522 - Haut-parleur de graves avant gauche
B105F 13 [009] - Circuit ouvert
[Tieftonlautsprecher Kanal 3: Unterbrechung (DC-Diagnose)]
Capture:
Date: 2023.11.22
Temps: 20:37:37
7175 - Fonctionnement limitÈ en raison de l'absence de message
U1111 00 [009] - -
[Tire pressure monitoring (0x07) - function restriction due to communication error - BapErr_retry not successful]
Capture:
Date: 2023.11.22
Temps: 20:37:36
BAP-BAP_Function_ID: 02
7206 - Fonctionnement limitÈ en raison de l'absence de message
U1111 00 [009] - -
[Brake (0x26) - function restriction due to communication error - BapErr_retry not successful]
Capture:
Date: 2023.11.22
Temps: 20:37:36
Adresse D6: Ctrl feu gauche 2 (A31) Labels: 7PP-941-572.clb
No. piËce Log: 7P5 941 572 A Mat: 7P5 941 572 A
PiËce: LED1L H06 0002
Jeu de donnÈes ASAM: EV_LEDMinMaxL_KEBODAVW481 001003
ROD: EV_LEDMinMaxL_KEBODAVW481.rod
VCID: 392F2DF919DA6C12084-806C
Adresse D7: Ctrl feu droit 2 (A27) Labels: 7PP-941-572.clb
PiËce: LED1R H06 0002
Jeu de donnÈes ASAM: EV_LEDMinMaxR_KEBODAVW481 001003
End----------(Elapsed Time: 05:11, VBatt start/end: 13.8V/14.0V)-----------
