Page 2 of 2 FirstFirst 12
Results 16 to 23 of 23
  1. #16
    Nov 2023
    Quote Originally Posted by clusters View Post
    Do not try and write his file, your read is not good!
    If you overwrite the eeprom you will corrupt it.
    Hi, Can you elaborate? How did you see it wasn't good?
  2. #17
    clusters's Avatar
    Mar 2015
    Canada
    By looking at the file structure, not using some crappy script.
    If people can't recognize a bad file they should not be trying to correct them.
  3. #18
    Nov 2020
    I would appreciate if y explain whats wrong with file structure.
  4. #19
    Nov 2023
    Can one of you legends verify and change this file? I bought better equipment, but was still getting an ORG error. I disconnected pin 6 and 7 after advice from another thread. Hopefully this is correct?
    Current reading should be 232861. Would like to go to 219000
    I'll be sure to give you thanks!
  5. #20
    clusters's Avatar
    Mar 2015
    Canada
    File is still not good
  6. The Following 2 Users Say Thank You to clusters For This Useful Post:
    Ihaveinternet (11th January, 2024)
  7. #21
    Nov 2023
    thanks for your time. Is this any better? Is there a way i can verify the structure myself, so I don't waste anyone's time?
  8. #22
    Nov 2023
    My UPA-USB fails a couple of the hardware tests on voltage being out of spec, and I think this is where I'm running into problems. My model doesn't have the variable resistor either. I have ordered another one and hope I will finally be able to get a good read.
  9. #23
    Nov 2020
    Quote Originally Posted by Ihaveinternet View Post
    Dont waste yr time with the chinese clones , its useless, check the original one , link attached
    https://www.elrasoft.com/uusps.htm
