KWP2000 is the best, but everyone has it's opinion
Hi.
For beginning chiptuning,i suggest not to do what our friend Paraver is telling.
KWP2000 is cloned 20USD serial programmer,for old K-Line based cars.
My suggestions go to
*MagPro2-OptiCan-Kess-CMD-MPPS Serial programmers
*Advantec or BeeProg paralell programmer
*Swiftec editing software
If you wanna start with cheap solutions,and less support:
ECM2001 6.2 editing software(avaible on DK for free)
CMD (canbus) Galetto (k-line)clone
Wellon paralell programmer
can u use the KWP2000 clone with ecm2001???
yes you can make files to be flashed with kwp2000 programmer with ecm2001 software.
But ecm2001 is not the way to go, its very bad software with very bad drivers database, you shuld use winols instead.
kwp2000+ was a very good programmer, and it still is for that price, even if it only does old cars, it still does alot of them and i never had any problems with it. it even does several cars that galletto clone cant do.
hola. mi consejo es tener el kwp2000+ y galletto para ecu 15. para ecu 16 tambi?n galleto y cmd1251. son programas baratos y compatibles con muchos coches.
hola. programas baratos y compatibles: kwp2000+ , galleto y dmc1251. muy compatibles
English please mate ....
WinOls is the best one ...
Best software???
Best software is the one that has SUPPORT.
Most all of the editors do not have detailed manuals on the use of the software and if they do they are very badly written. The people that write them seem to believe that everyone is a software-electronics expert and does not need detailed help.
Well, chip tuning is for automotive engineers ONLY that use the software as a tool to do the work THEY ONLY know how and WHY it should be like this and not like that...
No electronics or software guy has the mechanical knowledge to tune (change the mechanical parameters), of I.C engines... they only do this as a quick way to make easy and fast money and we all know the results of blown engines etc....
So the answer to this topic is easy I believe...
Speedy
Knowledge is to share... so if I have helped just press [Thank You + Rep.]...
Really....., what is the best soft?
But.
Checking files from PRO TUNERS i often dont see great differeces to what i do,whithout do shool for it,im no engineer.
But i saw some files,i believe they came from real pro s.
A G60 file for vw,no map had caracteristic of what is original from size...real big job.
Some old sierra and escort turbo files...
For these poeple i have LOT OF RESPECT
but telling you blow engines by doing what pro tuners do,is not thrue.
