Results 1 to 14 of 14
    Nov 2022
    Default What difference beetwen KT200 and KT200 II?
    KT200II ECU Programmer is better than KT200 in the following aspects:
    1. New protocols have been added, and more and more will be added frequently in the future.
    2. Fixed the automatic checksum problem of the first generation KT200, and the reading and writing efficiency has been greatly improved.
    3. Many new virtual files have been added to the server.
    4. Strengthened the protection of ECU, and will prompt you immediately if an operation error is made.
    5. Optimized server access efficiency.
    6.OBD reading and writing is stable.
    7.Support DELPHI DCM7.24 ECU
    8.Can work with htprog too
    9.New automatic function:Tricore Clone
    KT200II Read Write Bosch DQ380/381 OK
    KT200II New cables available
    Delco E38, E67, E84,E92
    New automatic function: tricore clone.
    Bosch 6L45, 6L50, 6L80, 6L90
    Marelli 8GMC
    Siemens SIM2K-305
    Bosch MG1CA007
    Delphi DCM7.24
    Phoenix L40
    TRW EMS2.4
    Bosch EDC17 C11
    Bosch MD1CS069
    New cables available:
    Bosch DQ380/381
    carmageddon's Avatar
    Italy
    the difference is the box....and the color of pcb
  3. The Following User Says Thank You to carmageddon For This Useful Post:
    GMXcool (29th November, 2023)
    dimitar's Avatar
    Same shit different packaging
    50w Soldering Iron
    Chisel
    Sometimes Hammer
    Italy
    i have it, is not shit if we speak about the job that can do...many possibility, stable tool, no problem for each ecu i did (also new ecu as md1, mg1, edc17, med17 etc)...the real problem is the "chip killer" inside that kt200 have (foxflash does not have it)....but soon the chip killer wont be a problem anymore
    Oct 2017
    Europe
    Deleted Post.
    Oct 2017
    Europe
    Quote Originally Posted by carmageddon View Post
    What do you mean " Chip killer" ?
    Italy
    inside kt200 is present module soldered that made only one job : kill the cpu time based…and kt200 need to go back to china seller
    dimitar's Avatar
    Can it be removed????
    50w Soldering Iron
    Chisel
    Sometimes Hammer
  10. #9
    Italy
    maybe also…need some test
  11. #10
    Mar 2009
    Europe
    What be problem if remove Chip killer,MCU block or not?
    When be register new KT200II,you thinks old KT200 MCU erased?
  12. #11
    Nov 2014
    Blackburn UK
    What about KT200 II still have inside chip killer ??
  13. #12
    Italy
    i'm wrong about the board inside the tool, is not chip killer, inside are the routine that allow the tool to start and work online...when grayed button Driver Selection mistake happen its only because this chip lost data to start and work...need only to change the board inside and tool relive...i did it on two tool, the factory sent me the board and i changed it
  14. #13
    dimitar's Avatar
    Where do you get this green board when you need one?? Do the factory sells them or??
    50w Soldering Iron
    Chisel
    Sometimes Hammer
  15. #14
    Italy
    the factory has connected to my pc and did all test to understand why happen this problem and tell me that the solution is change the green board inside, i had two dead tool (i buyed many of this tool) and it sent to me new spare to solder
