Page 2 of 7 FirstFirst 1234567 LastLast
Results 16 to 30 of 91
  1. #16
    V.I.P. Master of the IMMO
    lupu_sandu's Avatar
    In my immobox...
    I dind't test. Only read
  2. #17
    Jan 2018
    Good call there needs to be a multiprog thread
    Edc17c50 (bench mode,isn read success)
    Mercedes w203 eis (1J35D) SUCCESS
    CRAFTER-EZS-9S12XDP512 SUCCESS
    CAS3 (0L15Y) SUCCESS
    all of these done last week with the latest UPDATE:
    sw V1.1.2.0
    FIRMWARE V1.1.8
    DATABASE VERSION V52
  3. The Following 2 Users Say Thank You to bmujka For This Useful Post:
    BadeaCristian (26th February, 2024), lupu_sandu (26th February, 2024)
  4. #18
    Romania
    lupu_sandu Did you read some rh850 mcu from mqb dash? I'm interested if data is crypted .
  5. #19
    Romania
    Anyone read rh850 mcu from mqb dash? Data is crypted or plain?
  6. #20
    Jan 2018
    W209 cracking falied had to finish the job with vvdi prog
    ----Software version V1.1.2.0, Database version V52---
  7. The Following User Says Thank You to bmujka For This Useful Post:
    mikajna (4th April, 2024)
  8. #21
    Ninjor s's Avatar
    Aug 2020
    Bcm2
    very use full tool,it does checksum very well.
    the lesser you use your brain,
    the louder you use your mouth.
  9. The Following User Says Thank You to Ninjor s For This Useful Post:
    jarbo3a (11th March, 2024)
  10. #22
    lupu_sandu's Avatar
    In my immobox...
    MQB JCI dash tested on a couple of dashes - all ok
  11. The Following 4 Users Say Thank You to lupu_sandu For This Useful Post:
    bmujka (6th April, 2024), darknezz19 (18th March, 2024), mikajna (4th April, 2024), rob h (1st April, 2024)
  12. #23
    Jun 2017
    US
    I've seen a couple people say this can change isn on BMW dmes. Don't see an option for this.
  13. #24
    Jun 2017
    US
    Quote Originally Posted by bmujka View Post
    How are you doing checksum calculate? The menu for this gives a lot of options and variables. Was able to edit the isn on a msd80 @ 0x00001100 in the int flash area, and when reading the isn again, it's changed. The process log didn't say anything about checksum calc though, with google lense, as some of it's in Chinese.
  14. #25
    Feb 2014
    Any idea what happens when this counter runs out ?
    Remaining usage times: 1000
  15. #26
    Jan 2018
    AT25C128 from IVECO FFr success
  16. #27
    sniegavirs's Avatar
    Mar 2017
    Latvia
    Has anyone gotten that WIFI option to work? Multiprog and PC connected to the same router but SW doesn't see the device.
    P.S. Looks like this function is still in development. Even Ethernet option is not functioning.
  17. #28
    BMW EDC17C06 Bench mode read success
    VW MED9.1 Bench mode not successful
  18. #29
    Oct 2017
    EU
    Vw med17.5.5 bench and boot not works test V1 and V2
    Opel E98 bench not works
    Psa Edc17C60 bench Okay
    Psa mds1003 bench read Okay
    not possible to CKS
    When I help you
    PUSH on +THANKS and REP or
  19. #30
    auto techniek's Avatar
    Mar 2017
    Any idea if multi prog support writing Audi J518 elv emulator?
    J518 connector cable does not fit in multi prog.
