Page 3 of 7 FirstFirst 1234567 LastLast
Results 31 to 45 of 91
  1. #31
    sniegavirs's Avatar
    Mar 2017
    Latvia
    Opel Delco E98
    BENCH - Does not work. It reads the ID fine with all SW numbers but cannot read it.
    BOOT - Does not work. After read error it asks for password (OK that could be normal but there is no option to read the password in Bench or OBD - so useless..) And after you cancel that operation Multi Prog device hangs up and only way is to restart it with power switch.
    Also for some ECU's the Pinout information is confusing that could lead to burned HW (ECU/TCU or Multi Prog) where pinout picture is correct but top right pinout legend is numbered wrong.
    Also there are a lot of ECU's listed where inside memories are shown 0 and is not working.
    For example take Scania EMS S8 ECU
    Only option is BOOT. Pinout for external connector is correct but there is no information about actual BOOT connection on PCB where 3 wires should be connected near MCU.
    They are advertising this as ECU/TCU read/write/clone tool but it is very half-baked product at the moment.
  2. #32
    mikajna's Avatar
    Mar 2015
    VW Golf 5 GTI MED9.10 NOT work, cant connect to ecu
  3. #33
    VAG EDC17CP14
    INT EEPROM READ
    INT FLASH READ
    EXT FLASH Read data failed! Ending process
    The chip power has been turned off!
  4. #34
    sv2hqx's Avatar
    Jun 2014
    Quote Originally Posted by sharpshooter86 View Post
    VAG EDC17CP14
    INT EEPROM READ
    INT FLASH READ
    same on edc17c57
  5. #35
    V.I.P. Master of the IMMO
    lupu_sandu's Avatar
    In my immobox...
    Last update bring RH850 VAG to multi-prog
    What cable do we use? Same RH850 cable as Pad?
  6. #36
    sniegavirs's Avatar
    Mar 2017
    Latvia
    Quote Originally Posted by lupu_sandu View Post
    No. There will be new cable. Not available at the moment..
  7. The Following User Says Thank You to sniegavirs For This Useful Post:
    lupu_sandu (8th April, 2024)
  8. #37
    with Databse update V17 MED 9.1 now can read
  9. #38
    lupu_sandu's Avatar
    In my immobox...
    Read 2 read BCM from Porsche = ok, no need to remove components (same schematics as hextag).
  10. The Following User Says Thank You to lupu_sandu For This Useful Post:
    sniegavirs (12th April, 2024)
  11. #39
    sniegavirs's Avatar
    Mar 2017
    Latvia
    V19 - BMW CAS3+ Mask 0L15Y - Multi PROG sometimes struggles to crack the MCU. Sometimes the cracking takes a long time and sometimes it fails. VVDI Prog does it instantly very time you press read or write.
  12. The Following User Says Thank You to sniegavirs For This Useful Post:
    qwojtus (19th April, 2024)
  13. #40
    MACKIE's Avatar
    Jan 2011
    Helion Prime
    Any news about the cable for RH850 ?
    Mackie
    " I don't need help but difficulties. The harder the better. I work the best when in trouble."
  14. #41
    tepSIJA's Avatar
    Dec 2015
    OTP
    Quote Originally Posted by MACKIE View Post
    Mackie
    [In stock] XHORSE XDNPR8GL MQB RH850/V850 Adapter for VVDI Key Tool Plus
    https://www.vvdishop.com/wholesale/x...0-adapter.html
    Tempus Omnia Revelat
  15. #42
    MACKIE's Avatar
    Jan 2011
    Helion Prime
    That is adapter for vvdi key tool plus not for multiprog.
    Mackie
  16. #43
    sniegavirs's Avatar
    Mar 2017
    Latvia
    Quote Originally Posted by tepSIJA View Post
    He asked about RH850/V850 Adapter cable for Multi PROG not Key Tool Plus!!! This is Multi PROG thread!!!
  17. #44
    Quote Originally Posted by sniegavirs View Post
    You right. It read quickly than took ages to write it back, about a minute crack the CAS3 chip.
    Also if you read, no any possibilities to see the data or edit anything. Big upgrade of nothing.
    Competition like Obdstar or CGDI or Hexprog much more useful in ordinary staff, but obviously no that fully packed with thousands options like multiprog
  18. #45
    sniegavirs's Avatar
    Mar 2017
    Latvia
    V19 - Ford Continental SID211
    Bench - ID good, reading does not work.
    Boot - does not work, no ID and also it would not be possible to read because there is no option to read the MCU Password and Boot connection on PCB is wrong.
