Page 5 of 7 FirstFirst 1234567 LastLast
Results 61 to 75 of 91
  1. #61
    sniegavirs's Avatar
    Mar 2017
    Latvia
    Quote Originally Posted by jodge View Post
    in one word: R7F701407
    You say that you are lost with this stuff, but at the same time cannot answer to a simple question without dumb riddles...
    If you are asking about MQB48 license for reading RH850 and V850 dashboards, it is already included in Multiprog base package! It is literally written in every place it is sold in title and description. So no need to transfer anything anywhere!!!
  2. #62
    sniegavirs's Avatar
    Mar 2017
    Latvia
    Today Multiprog saved a car. It was a Peugeot with DCM3.5 ECU. Car was some time ago tuned with Magicmotorsport Flex in OBD mode, then it got modified at another tuner also in OBD mode with Autotuner and it got bricked in the process. Something to do with Flex applied OBD patch interfering with Autotuner OBD patching. After that it was not possible to read that bricked ECU in boot mode not with Transdata tool not with Flex. Reading stopped after 10%. So they brought that BRICK to me and I connected it to Multiprog in BOOT mode. It read it without problem. Fixed the file and wrote it back. ECU and the car is working again. Another proof where you cannot have enough tools. Where Flex, Autotuner and Transdata failed all together, new Multiprog saved the day.
  3. The Following 6 Users Say Thank You to sniegavirs For This Useful Post:
    electromech (6th June, 2024), jarbo3a (26th May, 2024), mikajna (25th May, 2024), tepSIJA (24th May, 2024), u.s (25th May, 2024), Weasel3 (25th May, 2024)
  4. #63
    tepSIJA's Avatar
    Dec 2015
    OTP
    Opel Meriva 2006 , engine 1.7d, 101hp, Ecu DENSO SH7055 eeprom93c56, Multiprog FAIL to read , Flex no problem bench full clone (eeprom+flash)
    Tempus Omnia Revelat
  5. #64
    EDC17cp20 R & W
    INT EEPROM
    INT FLASH
    EXT FLASH
    read and write successfully
  6. #65
    Oct 2016
    Device info:Manufacturer: Renesas
    Partname: R5F10C_D_Data_8KB_Read_SECURED
    8-bit bytes: 8KB
    read and write successfully...
  7. #66
    BMW FRM 2M25J/3M25J (9s12xeq384)
    R & W Repair
    successfully
  8. The Following User Says Thank You to sharpshooter86 For This Useful Post:
    jarbo3a (2nd June, 2024)
  9. #67
    that tool will be good in a year
    now and on customers who test it for them
    bcm2 elv adapt online offline -echange immodata -clone immodata sinchro bcm elv medc17 edc17 Crafter EZS e EDC17 sinchro -DPF/ EGR/ DTC/ removal/: IMMO ADAPT edc16 EDC17 edc17c64 C74 NOW WORKING MED17/MEV17/ VAG ecu clone full working all
    PCR2.1 FULL CLONE ou adapt, clone all edc17 me17 , etc / dash echange immodata repair immodata add key etc etc
  10. #68
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    i read some ecus with multi prog...... (simos 10.10 x2, and some edc16..) and wrote the eeprom in one of the simos 10.10...... works well.....
    and i just read a mc9s12xet512 secured...... eeprom and p flash looks ok, but i cant read d flash...... probably is a chip problem because the module it doesn't work......
    Η κότα έκανε το αυγό ή το αυγό την κοτα;
  11. #69
    Maartinj's Avatar
    Nov 2010
    Quote Originally Posted by Panathaole View Post
    post log from bottom when operation failed, enginners can look it
  12. #70
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    can't read a R7F701019 srs kia ecu..... vvdi can...... (not support R7F7010193 maybe????)
    EDIT:
    even vvdi prog can't manage to read that mcu....... i think something going on with that module.....
  13. #71
    MACKIE's Avatar
    Jan 2011
    Helion Prime
    Have problem with one R7F701402 from VW Crafter 2022. Multiprog read data ok but when insert crypted file in VVDI 2 it says "immo data ok" but no immo data. And when want to write KM it says "please collect and retry".
    I send file to support but no answer.
    Mackie
    " I don't need help but difficulties. The harder the better. I work the best when in trouble."
  14. #72
    lush29's Avatar
    Oct 2015
    Ezs st12 sprinter 2008 , read/write is not working, always failing on unlocking.
    Old vvdi prog read it in seconds.
    Still alot of bugs on this tool and is been out for almost 1 year soon
    Sent from my SM-S911B using Tapatalk
  15. #73
    sniegavirs's Avatar
    Mar 2017
    Latvia
    Quote Originally Posted by lush29 View Post
    1 year in development maybe but not OUT for sale. Yes it is NEW but most of the stuff that doesn't work and gets reported through feedback in next updates gets fixed.
  16. #74
    sniegavirs's Avatar
    Mar 2017
    Latvia
    Quote Originally Posted by MACKIE View Post
    Mackie
    I am doing 2019 TROC with exact R7F701402 MCU and have exact problem.
  17. #75
    Maartinj's Avatar
    Nov 2010
    Quote Originally Posted by sniegavirs View Post
    post file here and screen from your device when decode
