Hello guys,
112600-3842
21175-1213
Denso
Z1000 Kawasaki 2019
Could someone tell me, where the eeprom are located.
And what is written on the eeprom?
Hello guys,
112600-3842
21175-1213
Denso
Z1000 Kawasaki 2019
93c86 eeprom.rar
I have read the IC 502 position eeprom.
93C86.
Can someone make transponders?
Good job Rob so was ecu case and motherboard fuse together? Did you melt,cut,and peel it apart? Did you save your work, so other can learn off it. I’ll take the first front center row seat..
I did cut the cover, using a soldertip, about 330dgrs.
Carefull, wtih the board, there are some small resistors!
The dump,is not recognized by tango.
I dont have tmpro, perhaps they cover these.
Some say, the flash can be read.
And be made immo off.
I will try that.
Here do find a thread, about where to cut.
https://www.digital-kaos.co.uk/forum...aki-21175-1212
I used a solder tip, to make a small hole.
With a clamp, i could read in circuit.
The key, to fit the ignition, i used lishi.
No need to pick, just decode.
Hello, immo off for this bike its in ecu i can do it
But what tool, can read flash?
MMS flex, can not
