Page 22 of 200 FirstFirst ... 1217181920212223242526273272122 ... LastLast
Results 316 to 330 of 2986
  1. #316
    Hungary
    Hell? Help My.
    FORD 6000 CD
    SERIAL NO:V288445
    PART NO:6S61-18C815-AJ
  2. #317
    Poland Wroclaw
    please help
    ford 6000 cd
    part no .8m5t-18c815-ab
    serial V045670
  3. #318
    Oct 2011
    Default visteon CD 6000 code
    Hallo, can you help my with ford visteon CD6000 part. 5M5T-18C815-FA ser. no. M010397
    thanke you!!
  4. #319
    Jan 2012
    Try 9792...
  5. #320
    Oct 2011
    I tried the code, but it does not work. I figured this code and calculator, but valid for another model 6000 series. this is a single cd model 2005 Year of manufacture. I can read memory, but i cant see it on pcb
  6. #321
    Jan 2012
    Can you send radio main pcb photo?
  7. #322
    Oct 2011
    radio foto
  8. #323
    Jan 2012
    This ST92F250 code in OTP memory.Can not be write OTP memory.Can not be change code!
    if your radio orginal chip & orginal pcb your code via serial algo 9792.Check your radio power supply connections.
  9. #324
    Jan 2012
    Radio off Push buttons 2-6 push button ON
    Radio off Push buttons 1-6 push button ON
    Radio off Push buttons 5-6 push button ON
    if ok serial number.Maybe your radio flash memory corrupt can not find good adress via OTP.
  10. #325
    Top Poster flurthi's Avatar
    Mar 2011
    Tiran.Albania.
    Default PART NAMBER VP7S7F-18C821-EA V 015792
    PART NAMBER VP7S7F-18C821-EA V 015792 thanks ....
  11. #326
    wembleyhill's Avatar
    Feb 2009
    Default Please Help
    Ford V121287
    CD 6000
    SINGAL CD - KW2000
    Part No 8M5T-18C815-AB
    Thank You
  12. #327
    Ford 6000CD
    part No: 6S61-18C815-AJ
    SERIAL No: V098253
    MODEL Single CD - KW2000
    Thank you
  13. #328
    Mar 2012
    SERIAL No: V045089
    Please help, code. Thanks.
  14. #329
    Default Radio code
    Please help code this radio
    6S61- 18C815
    V069118
    Krisztian
  15. #330
    DK Veteran rachmach's Avatar
    Jan 2011
    Workshop
    hello I need code radio ford focus
    part no 8M5T 18C8-15-AB
    serial no V045352
    tankh's in advance
