Page 79 of 200 FirstFirst ... 2969747576777879808182838489129179 ... LastLast
Results 1,171 to 1,185 of 2986
  1. #1171
    Mar 2018
    Hello. Can you give unlock code for S/N V005140. Thx.
  2. #1172
    Albert G's Avatar
    Apr 2016
    Quote Originally Posted by clustev View Post
    Your code is .. 9549
  3. The Following 2 Users Say Thank You to Albert G For This Useful Post:
    gu3ss (5th March, 2018), irfa (5th March, 2018)
  4. #1173
    morfej's Avatar
    005140 = 9549
  5. The Following 2 Users Say Thank You to morfej For This Useful Post:
    gu3ss (5th March, 2018), lwd11 (5th March, 2018)
  6. #1174
    Mar 2018
    Quote Originally Posted by Albert G View Post
    Your code is .. 2226
    Thank you. Is there a way to test the code if it is not asked yet? I want to add a music box, and need to disconnect, I don't want to face a wrong code problem. Or this code is 100%?
    Thanks.
  7. #1175
    Bulgaria
    Quote Originally Posted by darton81 View Post
    Thanks.
    There is never a 100% warranty on decoding from a serial number because it is possible for some decoder to change it in the past !!
    Unless you are the first owner of the car and the radio!
    This is the original factory code.
  8. The Following 2 Users Say Thank You to bogege For This Useful Post:
    Albert G (5th March, 2018), lwd11 (5th March, 2018)
  9. #1176
    Mar 2018
    Quote Originally Posted by bogege View Post
    Do you know a way to test the code without disconnecting it?
  10. #1177
    Mar 2018
    Thank you I hope it fits, but I can not enter it. Figures are entered by a single press of the buttons, not several times. After pressing the * or circle button the device simply turns off.
  11. #1178
    Bulgaria
    Specify the full model of your radio? Most probably you enter the code!
    Try confirming the code with this button #.
  12. #1179
    Bulgaria
    You can make a power supply bypass to the main board and then disconnect the connectors!
  13. #1180
    Mar 2014
    Hello , can someone find code for a visteon 6000cd with sn. V077591? Thanks
  14. #1181
    Poland KRK
    Hi. Need code for radio ford 6000.Serial v006656. Can anyone help?
  15. #1182
    lucic66's Avatar
    Aug 2015
    .......9766.......
    Quote Originally Posted by cudzy View Post
  16. The Following 3 Users Say Thank You to lucic66 For This Useful Post:
    cudzy (12th March, 2018), irfa (7th March, 2018), lwd11 (7th March, 2018)
  17. #1183
    lucic66's Avatar
    Aug 2015
    ......3847....your code
    Quote Originally Posted by RW74 View Post
  18. The Following 3 Users Say Thank You to lucic66 For This Useful Post:
    irfa (7th March, 2018), lwd11 (7th March, 2018), RW74 (7th March, 2018)
  19. #1184
    Mar 2018
    Hello , can someone help me with code for V261382? Thanks!
  20. #1185
    lwd11's Avatar
    Jun 2016
    Quote Originally Posted by nnikolajs View Post
    TRY ... 0528
  21. The Following 2 Users Say Thank You to lwd11 For This Useful Post:
    Albert G (7th March, 2018), bogege (7th March, 2018)
