Hell? Help My.
FORD 6000 CD
SERIAL NO:V288445
PART NO:6S61-18C815-AJ
Hell? Help My.
FORD 6000 CD
SERIAL NO:V288445
please help
ford 6000 cd
part no .8m5t-18c815-ab
serial V045670
Hallo, can you help my with ford visteon CD6000 part. 5M5T-18C815-FA ser. no. M010397
thanke you!!
Try 9792...
I tried the code, but it does not work. I figured this code and calculator, but valid for another model 6000 series. this is a single cd model 2005 Year of manufacture. I can read memory, but i cant see it on pcb
Can you send radio main pcb photo?
radio foto
This ST92F250 code in OTP memory.Can not be write OTP memory.Can not be change code!
if your radio orginal chip & orginal pcb your code via serial algo 9792.Check your radio power supply connections.
Radio off Push buttons 2-6 push button ON
Radio off Push buttons 1-6 push button ON
Radio off Push buttons 5-6 push button ON
if ok serial number.Maybe your radio flash memory corrupt can not find good adress via OTP.
PART NAMBER VP7S7F-18C821-EA V 015792 thanks ....
Ford V121287
CD 6000
SINGAL CD - KW2000
Part No 8M5T-18C815-AB
Thank You
Ford 6000CD
part No: 6S61-18C815-AJ
SERIAL No: V098253
MODEL Single CD - KW2000
Thank you
SERIAL No: V045089
Please help, code. Thanks.
Please help code this radio
6S61- 18C815
V069118
Krisztian
hello I need code radio ford focus
part no 8M5T 18C8-15-AB
serial no V045352
tankh's in advance
