Results 1 to 15 of 2986
Hybrid View
    Jan 2012
    This ST92F250 code in OTP memory.Can not be write OTP memory.Can not be change code!
    if your radio orginal chip & orginal pcb your code via serial algo 9792.Check your radio power supply connections.
    Jan 2012
    Radio off Push buttons 2-6 push button ON
    Radio off Push buttons 1-6 push button ON
    Radio off Push buttons 5-6 push button ON
    if ok serial number.Maybe your radio flash memory corrupt can not find good adress via OTP.
    Top Poster flurthi's Avatar
    Mar 2011
    Tiran.Albania.
    Default PART NAMBER VP7S7F-18C821-EA V 015792
    PART NAMBER VP7S7F-18C821-EA V 015792 thanks ....
    wembleyhill's Avatar
    Feb 2009
    Default Please Help
    Ford V121287
    CD 6000
    SINGAL CD - KW2000
    Part No 8M5T-18C815-AB
    Thank You
