Page 1 of 6 123456 LastLast
Results 1 to 15 of 80
    Aug 2020
    Default ToyoLex 4 Black Diamond Edition - FREE FOR ALL!
    ToyoLex 4 Black Diamond Edition, the first application on the world designed exclusively for DISABLE IMMOBILIZER SYSTEM TROUGH FLASH FILE on Toyota, Lexus and Hino (N04 engines). It has the following characteristics:
    - Supports Generation 1, 2 and 3 files from Toyota and Lexus Denso ECUs with the below MCU cores:
    - Denso Generation 3: R7F701202 and R7F701216 .
    - Denso Generation 2: D76F0199GD, D76F0196F1, D76F0219F1.
    - Denso Generation 1: NEC 76F00XX series (Currently not support old Denso core 76F0004GD mask found on some 2001-2004 MY cars)
    - Exclusive algorithm that recognizes immobilizer block into Flash file, doing the disable task only in such memory and with only one click.
    - Automatic special function that do erasing of DTCs togheter with Immobilizer disable function.
    - By doing the process only in Flash memory, most immobilizer disable tasks can be performed through the OBD II port without the need to open the ECU!
    - Not more cut / uninstall any wire or module after do Immo off, simply program the file generated by ToyoLex 4 BDE and start the engine!
    - Support and process files from ALL Denso ECUs for DIESEL and GASOLINE engines.
    - Work with ZERO risk on Denso Generation 3 ECUs.
    - Allow binary files from any Flashing tool of the market that support Denso ECUs for Toyota and Lexus cars.
    - Tested on systems with key blade and START-STOP systems.
    - NOT support ECUs for Hybrid Vehicles (1) and locked Gen 3 ECU by wrong programming.
    - Not tested on Factory virgin ECUs (New not installed yet ECUs).
    (1) This will be noticed by the application when opening a Hybrid Vehicle file.
    New link added
    HaynesPro online 2024 + AC 2022.02a available, message for where to get them!
  2. The Following 54 Users Say Thank You to crouchinggerbil For This Useful Post:
    258 (1st January, 2024), A1exSun (9th June, 2024), abrush32 (11th June, 2024), Amir15 (27th May, 2024), Arkus73 (21st April, 2024), assist9 (17th May, 2024), Autoexpress (6th June, 2024), beltronics (24th December, 2023), ChaunBoon (14th June, 2024), cupsi (17th May, 2024), elgarage (23rd May, 2024), fatzz (Today), fudeauto (15th June, 2024), haytem (24th December, 2023), Henrike21 (26th December, 2023), Inquizit0r (16th May, 2024), jedrszczak (11th June, 2024), jevgensolo (27th December, 2023), jkewl999 (20th June, 2024), joejam (21st January, 2024), jomberykaso (Today), Jozua (11th June, 2024), jp74746 (26th May, 2024), js29584 (1st February, 2024), JU57FL1P (22nd May, 2024), large12390 (24th December, 2023), Luigi84 (23rd May, 2024), maichi2010 (16th May, 2024), Michal Benni (31st May, 2024), mkii (24th December, 2023), Nee 633 (Yesterday), NONO59 (7th May, 2024), oRiEpsilon (7th May, 2024), paulis (16th May, 2024), paulsta (15th May, 2024), peugeotexpert (27th May, 2024), pinotec (25th December, 2023), rayssant (5th May, 2024), rybenz (2nd January, 2024), SALAS (18th May, 2024), sharpshooter86 (1st January, 2024), shittu191 (18th May, 2024), shtyrya2 (13th January, 2024), stanislav georgiev (24th December, 2023), stormb (25th May, 2024), superjet (25th December, 2023), svenin53 (7th May, 2024), tom23136 (25th December, 2023), vjjiyane (11th June, 2024), Willinickersen (26th December, 2023), zalimhan74 (21st April, 2024)
  3. #2
    Sep 2010
    Thanks boss
    But dont accpt donlowed
    May u uplode in anther site
    Regardd
    Feb 2016
    United Kingdom
    There are Diamond and Black editions at the moment. Is there any plans to release Blue and Pink editions in the nearest future too? ��
    Aug 2015
    this toyoylex version wont work without license...
    Jun 2022
    reup please
    Aug 2020
    Quote Originally Posted by dtip View Post
    Works for me, internet must be on.
    Aug 2020
    New link added
    Aug 2020
    New link added
  10. #9
    Nov 2016
    Enniskillen
    Data package from February 11th.
    Size: 322 BThe data package cannot be downloaded anymore, it was deleted from the server.
    Can you update a link Please. Cant download anymore
  11. #10
    Aug 2020
    Quote Originally Posted by Arcadius82 View Post
    New link added
  12. #11
    Jun 2022
    can you update link please?
  13. #12
    Nov 2023
    Can someone post it on Google or Mega, otherwise it turns out to be a link to the download link
  14. #13
    Aug 2020
    New link added
    Installation password mhhavto.com
  15. The Following User Says Thank You to crouchinggerbil For This Useful Post:
    keino1 (7th May, 2024)
  16. #14
    Dec 2017
    jamaica
    it ask for password the program
  17. #15
    Nov 2023
    Thanks + Rep +
  18. The Following User Says Thank You to oRiEpsilon For This Useful Post:
    Mohammedmiki (14th May, 2024)
