Results 1 to 15 of 15
    Dec 2023
    Default How to read EDC15 eeprom with CH340 cable
    I am trying to read EEPROM on my EDC15 skoda octavia (intermittent immo no start / shutoff after some 2 sec). I only have "blue cheap" cable currently, I installed some CH341 drivers I found on this forum.
    Tried a lot of software,
    1. VAG eeprom programmer cannot read anything, says ECU not found or Rx timeout
    2. VAG K+CAN commander 2.5 is not able to connect just times out... setting is on K-Line communication and ports are set up properly in ini file
    3. https://github.com/gmenounos/kw1281test can ReadIdent and DumpEdc15Eeprom but the data is garbage
    I need to immo off so it doesn't leave me stranded ever again. I studied a lot, I think I can handle the eeprom patching, I just can't read it
    Is it possible at all with my cable? OS is Windows 7 in VirtualBox (I can handle that part without issues, incl. usb filters and other stuff). Host OS is linux but it doesn't matter as the cable communicates but nothing at all works with it. So I don't suspect the problem is in the "virtual machine" mode of running (I don't have any other laptop, just my primary one).
    Thank you very much for any further info, it is greatly appreciated.
    Feb 2018
    Try it with this SW. It is on KKL cable.
  3. The Following 2 Users Say Thank You to western6089 For This Useful Post:
    Hackerman (25th February, 2025)
    Dec 2022
    hi so as to read eeprom on this ecu you must get out ecu of the car, open it for boot mode and make connection for bench mode then you should able make a reading of this ecu
    Dec 2023
    thank you all for your help I did a clean install of windows 7 now that I know precisely what I want to install and do, and the result is, ONLY kw1281test is able to read the eeprom. The data is not garbage, it looks proper, contains VIN and login and such. I was able to perform immo OFF on the file using edc15 calc.
    Now I have a problem I don't have a tool to WRITE the eeprom back.
    Every tool, including VAG eeprom programmer, including VAG commander, also the version posted by @vestern6089 does not communicate using my CH340 cable AT ALL.
    All I get is Rx timeout from VAG eeprom programmer, timeouts from VAG commander, VAG EEPROM TOOL also timeout.
    I don't know why this is the case, the cable clearly works, as kw1281test IS able to read the eeprom using my cable through OBD port under the steering whl.
    Sadly, kw1281test currently doesn't have the option to write the EDC15 eeprom back.
    How can I write the eeprom, what could be the issue of no communication using any other program? I really would like to update the eeprom using the OBD port, I don't have any eeprom programmers, and I would like to keep the ECU intact from hardware point of view.
    Thank you very much for any suggestions
    Dec 2023
    I've done some more debugging / digging, my friend has a BMW INPA (K+DCAN) cable with FTDI chip. So I borrowed it, installed VCP drivers from FTDI directly, and my findings are as follows:
    1. VAG eeprom programmer can't read the eeprom (Rx timeout) in both switch positions on the cable
    2. VAG eeprom programmer now magically can read engine fault codes in both switch positions (it can't do so with CH340 cable)
    3. VAG commander still doesn't work at all
    4. kw1281test is now NOT able to dump the eeprom using this cable (is able to ReadIdent though) in both switch positions (both switch positions give a different error when trying to dump the eeprom)
    So, 2 cables, 2 chips, very very mixed results. Both cables work as multiple programs can at least partially work with them.
    What am I missing? Why can't I get VAG eeprom programmer working? Also why the inconsistent behaviors? Shouldn't the cables be wired identically (OBD kkl pin wise), and just differ in the chip that does the serial communication?
    Feb 2018
    What year of manufacture is the car, what unit is there. Write the exact identification of the unit.
    Dec 2023
    It's manufactured mid-2001, exact details are: (from kw1281test)
    Protocol is KW 1281 (8N1)
    ECU: 038906012H 1,9l R4 EDC 0000SG 3332
    Software Coding 00002, Workshop Code: 31480
    Sending ReadIdent block
    Ident: TMBCG41UX22558883 SKZ7Z0A1047529
    Sending EndCommunication block
    Thank you
    Feb 2018
    You are making a mistake somewhere, because the software I sent you must work at 100%. Or you don't have it set to K line.
    Alternatively, your unit is defective.
  10. #9
    Dec 2023
    I am sending a couple of screenshots from the virtual machine session. Read eeprom operation always times out. Resetting the ignition does not help. Does everything seem correct, or do I need to set anything else?
    In tester.ini, KWP2000 protocol produces the same results. Running VAG commander as administrator also does not help.
    Thank you very much
  11. #10
    Dec 2023
    More screenshots
  12. #11
    Dec 2023
    I noticed one thing. At first I wanted to record a video of the VM session, it hogged the cpu and then even kw1281test was working flaky (timing out and such). Timing on the serial port seems to be super inportant to keep precise.
    I reduced ram on the VM and instead of 2 cores I gave it one, also I've set windows power profile to "maximum performance".
    Will try again, and if it still doesn't work, I will borrow another laptop from someone with real windows installation and try it that way.
    This assumes all other settings are correct, which I hope they are.
    Thank you a lot!
  13. #12
    Dec 2023
    I can sadly confirm it does not work on a real windows 10 installation as well, same behavior as in virtual windows 7.
    Pictures of cable attached. I am waiting for k+can software + cable bundle from ebay, in the meantime, if anyone has any suggestions, they are much appreciated.
  14. #13
    Hi vilo999, if you subscribed to this thread, maybe you have gone further with your reserches on EDC15 ECU.
    I'm trying to read the epprom of a sililar ECU without success. I've tried two cheap specific cables bought from AliExp. without success on each one ..
    The exact model of mine is : EDC15V (diesel 90ch ALH engine). I don't know if the ECU is before or after 1999. It seems to be adifference after this year.
    The cables / softwares used are those two ones :
    - VAG-K+KAN that should work with K+CAN Commander 1.4 : https://fr.aliexpress.com/item/32281...yAdapt=glo2fra
    - VAG Eeprom Programmer Reader 1.20 : https://fr.aliexpress.com/item/10050...yAdapt=glo2fra
    If someone can help, it would be welcome
    Happy new year !
  15. #14
    Feb 2025
    Same issue here.
    I am unable to make eeprom programmer or K+CAN Commander work with my VAG KKL 409.1 cable.
  16. #15
    Feb 2025
    What is the password for VAG COMMANDER?
