Hello.
I realy fuc*&% up a few days ago and changed wrong byte and bits in 03-ABS, Now its lots of fault codes.
When i try to change the byte back to 20 i get: Coding rejected Error 31 out of range
I tryed to disable ASR/ESC and i did, But tcs, abs, and TPMS is glowing in the dashboard!
i made backup of everything 1 year ago but that usb stick is dead.
Ill hope someone here can help me out.
Its a skoda octavia mk2.5 VRS 2010
Thursday,28,December,2023,20:05:43:00009
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 11 x64
VCDS Version: 23.3.1.0 (x64)
Data version: 20230421 DS346.2
www.Ross-Tech.com
Dealer/Shop Name: Privaten
VIN: TMBUH61Z3A2101033 License Plate:
Mileage: 207080km-128673mi Repair Order:
Chassis Type: 1Z-SK35 (1K0)
Scan: 01 03 08 09 10 15 16 17 19 25 2B 42 44 46 4C 52 55 56 62 72
VIN: TMBUH61Z3A2101033 Mileage: 207080km-128673miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: Cannot be reached 1100
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Not registered 0001
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
2B-Steer. Col. Lock -- Status: Cannot be reached 1100
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Not registered 0011
46-Central Conv. -- Status: OK 0000
4C-Tire Pressure II -- Status: Not registered 0001
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (CEG) Labels: 03L-906-022-CBA.clb
Part No SW: 03L 906 022 RD HW: 03L 906 022 GA
Component: R4 2.0l TDI G000SG 9977
Revision: 13H03--- Serial number:
Coding: 0000072
Shop #: WSC 83968 792 591558
VCID: 78FF5DE70BD34253F3-802C
VINID: 91D4A560606A0D10810010030C5BA490FC
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (J104) Labels:. 1K0-907-379-60EC1-AJ.lbl
Part No SW: 1K0 907 379 AH HW: 1K0 907 379 AH
Component: ESP MK60EC1 H30 0107
Revision: 00H30001
Coding: 143B601C092200FB280B06E7901C0042340C00
Shop #: WSC 73430 790 00999
VCID: 78FF5DE7CBD34253F3-802C
7 Faults Found:
01423 - Lateral Acceleration Sensor (G200)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 200
Mileage: 207048 km
Time Indication: 0
Date: 2018.05.20
Time: 02:08:17
Freeze Frame:
Count: 2
Count: 32768
Count: 4608
Count: 328
Count: 53013
Count: 223
Count: 61440
Count: 0
01542 - Yaw Rate Sensor (G202)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 200
Mileage: 207048 km
Time Indication: 0
Date: 2018.05.20
Time: 02:08:17
Freeze Frame:
Count: 2
Count: 32768
Count: 4608
Count: 327
Count: 53013
Count: 223
Count: 61440
Count: 0
01486 - System Function Test Activated
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 160
Mileage: 206987 km
Time Indication: 0
Date: 2018.05.20
Time: 00:56:45
Freeze Frame:
Count: 3
Count: 2
Count: 12800
Count: 320
Count: 50432
Count: 0
Count: 0
Count: 0
00778 - Steering Angle Sensor (G85)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 160
Mileage: 206987 km
Time Indication: 0
Date: 2018.05.20
Time: 00:56:45
Freeze Frame:
Count: 3
Count: 2
Count: 12800
Count: 166
Count: 50432
Count: 0
Count: 0
Count: 0
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 2
Fault Frequency: 1
Reset counter: 160
Mileage: 206987 km
Time Indication: 0
Date: 2018.05.20
Time: 00:56:45
Freeze Frame:
Count: 3
Count: 2
Count: 12800
Count: 295
Count: 50432
Count: 0
Count: 0
Count: 0
01309 - Power Steering Control Module (J500)
Freeze Frame:
Fault Status: 01101000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 160
Mileage: 206987 km
Time Indication: 0
Date: 2018.05.20
Time: 00:56:45
Freeze Frame:
Count: 3
Count: 2
Count: 12800
Count: 8212
Count: 50432
Count: 0
Count: 0
Count: 0
01487 - System Function Test
000 - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 161
Mileage: 206987 km
Time Indication: 0
Date: 2018.05.20
Time: 01:00:10
Freeze Frame:
Count: 2
Count: 0
Count: 4608
Count: 321
Count: 50488
Count: 1
Count: 768
Count: 0
Address 08: Auto HVAC (J255) Labels:| 5K0-907-044.clb
Part No SW: 3T0 907 044 AS HW: 3T0 907 044 AS
Component: Climatronic H15 0401
Revision: 00005001
Coding: 0000000002
ASAM Dataset: EV_Climatronic A01006
ROD: EV_ClimaAutoBasis_SK35.rod
VCID: 03053A0B8A15118BD6-8056
Address 09: Cent. Elect. (J519) Labels:. 1K0-937-08x-09.clb
Part No SW: 1K0 937 087 D HW: 1K0 937 087 D
Component: BCM PQ35 H 103 0575
Revision: 00103 AG
Coding: 00180AB8B85BB3C0C0080080110091E4437000AE626D8560E4 0440040000
VCID: 326BAFCF6D2F68030D-8066
Subsystem 1 - Part No: 1Z1 955 119 C Labels: 1KX-955-119.CLB
Component: Wischer 20021 22 0601
Coding: 00DFB7
Subsystem 2 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 180210 05 54 0403
Coding: 0730ED
Subsystem 3 - Part No: 1Z0 951 171
Component: Innenraumuebe 008 5101
6 Faults Found:
01134 - Alarm Horn (H12)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 159
Mileage: 206941 km
Time Indication: 0
Date: 2018.05.20
Time: 05:48:55
Freeze Frame:
Term 15 On
Voltage: 14.15 V
ON
ON
Term 50 Off
OFF
OFF
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 159
Mileage: 206941 km
Time Indication: 0
Date: 2018.05.20
Time: 05:48:55
Freeze Frame:
Term 15 On
Voltage: 14.25 V
ON
ON
Term 50 Off
OFF
OFF
01504 - Bulb for License-Plate Light (X)
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 2
Fault Frequency: 24
Reset counter: 160
Mileage: 206941 km
Time Indication: 0
Date: 2018.05.20
Time: 05:48:59
Freeze Frame:
Term 15 On
Voltage: 14.15 V
ON
ON
Term 50 Off
OFF
OFF
01598 - Drive Battery Voltage
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 6
Fault Frequency: 10
Reset counter: 201
Mileage: 206941 km
Time Indication: 0
Date: 2018.05.20
Time: 05:50:19
Freeze Frame:
Term 15 On
Voltage: 13.95 V
ON
ON
Term 50 Off
OFF
OFF
03156 - Sensor for Anti-Theft System (G578)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 4
Fault Frequency: 8
Reset counter: 199
Mileage: 206949 km
Time Indication: 0
Freeze Frame:
Term 15 Off
Voltage: 12.85 V
OFF
OFF
Term 50 Off
OFF
OFF
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 2
Fault Frequency: 20
Reset counter: 200
Mileage: 206949 km
Time Indication: 0
Date: 2018.05.20
Time: 21:03:44
Freeze Frame:
Term 15 On
Voltage: 11.65 V
ON
ON
Term 50 Off
OFF
OFF
Address 10: Park/Steer Assist (J446) Labels:. 1Z0-919-475-V1.clb
Part No SW: 1Z0 919 475 B HW: 1Z0 919 475
Component: PARKHILFE 4K H06 0006
Revision: -------- Serial number: 66641005003453
Coding: 100002
VCID: 408FF507D383CA938B-8014
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 T HW: 1K0 909 605 T
Component: Q6 AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 0038PD2K24B2
Coding: 0020790
VCID: 3D718CF36471A77BE0-8068
Subsystem 1 - Serial number: 6332MSME4F206D43I
Subsystem 2 - Serial number: 6342MSME50142A510
Subsystem 3 - Serial number: 6351HSME203A1332Y
Subsystem 4 - Serial number: 6361HSME203B5C1FH
Address 16: Steering wheel Labels: 1K0-953-549-MY9.lbl
Part No SW: 1K0 953 549 CQ HW: 1K0 953 549 CQ
Component: J0527 053 0111
Coding: 0000034
VCID: 03053A0B4215118BD6-8056
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
Part No SW: 1Z0 920 803 J HW: 1Z0 920 803 J
Component: KOMBI H05 0305
Serial number: 00000000000000
Coding: 110E00
Shop #: WSC 73430 031 00999
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04052
ROD: EV_Kombi_UDS_VDD_RM09_004_SK35.rod
VCID: 3B7582EBB265A94BDE-806E
Address 19: CAN Gateway Labels:. 1K0-907-530-V4.clb
Part No SW: 1K0 907 530 AD HW: 1K0 907 951
Component: J533 Gateway H16 0233
Revision: H16 Serial number: 4520K102200714
Coding: A9A17F04000202012302
VCID: 69D908A34079EBDB7C-803C
3 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 159
Mileage: 206825 km
Time Indication: 0
02811 - Control Module for Electronic Steering Column Lock (J764)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 159
Mileage: 206825 km
Time Indication: 0
01044 - Control Module Incorrectly Coded
000 - -
Freeze Frame:
Fault Priority: 1
Fault Frequency: 2
Reset counter: 160
Mileage: 206825 km
Time Indication: 0
Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H05 0305
Coding: 000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03005
ROD: EV_Immo_UDS_VDD_RM09_VW21.rod
VCID: 6ADB77AF8D7FE0C375-803E
Address 2B: Steer. Col. Lock
Cannot be reached
Address 42: Door Elect, Driver Labels:. 1K0-959-701-MIN3.clb
Part No SW: 1T0 959 701 T HW: 1T0 959 701 T
Component: Tuer-SG 009 2113
Coding: 0004340
VCID: 489FED273BB3F2D343-801C
Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 74 3001
Revision: 00H17000
VCID: 3169A0C3A829531B74-8064
1 Fault Found:
00750 - Warning Lamp
013 - Check DTC Memory - MIL ON
Freeze Frame:
Fault Status: 11101101
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Freeze Frame:
Voltage: 12.13 V
DD
Temperature: 26.0 C
RPM: 0 /min
Speed: 0.0 km/h
Speed: 0.0 km/h
Count: 0
Address 4C: Tire Pressure II
Cannot be reached
Address 52: Door Elect, Pass. Labels:. 1K0-959-702-MIN3.clb
Part No SW: 1T0 959 702 R HW: 1T0 959 702 R
Coding: 0000244
VCID: 479DEE1B36ADFDAB4A-8012
Address 55: Headlight Range Labels: 5M0-907-357-V2.clb
Part No SW: 5M0 907 357 C HW: 5M0 907 357 C
Component: AFS-Steuergeraet 0142
Revision: 00H04000 Serial number:
Coding: 1507354
VCID: 3467A9D7573B66331F-8060
Subsystem 1 - Part No: 7L6 941 329 B Labels: 3D0-941-329.CLB
Component: AFS-Lst.-Modul l 0005
Coding: 00000023
Subsystem 2 - Part No: 7L6 941 329 B Labels: 3D0-941-329.CLB
Component: AFS-Lst.-Modul r 0005
Coding: 00000023
1 Fault Found:
004 - No Signal/Communication - MIL ON
Freeze Frame:
Fault Status: 11100100
Fault Priority: 6
Fault Frequency: 2
Reset counter: 159
Mileage: 206949 km
Time Indication: 0
Date: 2018.05.20
Time: 21:57:50
Freeze Frame:
Voltage: 13.63 V
Speed: 0.0 km/h
ABS 1
Address 56: Radio (J503) Labels:. 5M0-035-1xx-56.clb
Part No SW: 1Z0 035 156 F HW: 1Z0 035 156 F
Component: BOLERO 009 0053
Revision: 0A001001 Serial number: SKZ1Z3K8440093
Coding: 0D0004000401
VCID: 356194D39C417F3B28-8060
2 Faults Found:
00856 - Radio Antenna
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 160
Mileage: 206987 km
Time Indication: 0
Date: 2018.05.20
Time: 00:21:32
03138 - Input AUX IN
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 160
Mileage: 206987 km
Time Indication: 0
Date: 2018.05.20
Time: 00:21:27
Address 62: Door, Rear Left Labels:. 1K0-959-703-GEN3.clb
Part No SW: 5K0 959 703 A HW: 5K0 959 703 A
Component: Tuer-SG 007 2101
Coding: 0000144
Shop #: WSC 73430 790 1012551
VCID: 326BAFCFAD2F68030D-8066
Address 72: Door, Rear Right Labels:. 1K0-959-704-GEN3.clb
Part No SW: 5K0 959 704 A HW: 5K0 959 704 A
Coding: 0000144
VCID: 3365AACB5235610B06-8066
End-------------------------(Elapsed Time: 02:35)--------------------------
