Results 1 to 15 of 16
    Jul 2016
    Default Passat 2.0tdi BKP P0299 and limp mod solution needed
    Hi, Passat 2.0tdi BKP engine PPD 1.5 ecu P0299 and limp mod solution needed
    n75,map sensor changed , egr off, turbo hoses were changed, but it does not exceed 3200 rpm at full load, it gives error code p0299 and limp mode.
    SW: 6576286144
    Engine: R4 2.0l PPD1.5
    SW upg.: 03G906018CE 9707
    rafal's Avatar
    UK - PL
    make diagnostic of all inlet by smoke
    also check exhaust if not blocked
    if mechanical problem in car - any mod in map will not help you
    need help
    now my goal is to buy xp-005
    who will help?
    Jul 2016
    Quote Originally Posted by rafal View Post
    There is a swirl flap on the intake manifold. Could this cause a malfunction? I will remove the intake manifold.
    Aug 2019
    dirty turbo geometry
    Nov 2017
    Dobruja
    i like this thread... Let's see what other things did the man on that car and resume the problem to the exact issue.
  6. The Following 2 Users Say Thank You to volodin69 For This Useful Post:
    DiegoStud (8th January, 2024), rafal (6th January, 2024)
    Jan 2020
    Potential causes of a P0299 turbo underboost code include:
    * Intake (induction) air restriction or leak Failed or damaged turbocharger (sticking, binding, etc.)
    *Faulty boost/charge pressure sensor Faulty wastegate bypass regulator valve
    Jul 2016
    A problem was detected in the turbo hose o-ring. O-ring replacement. There is no p0299 error code. turbo pressure increases to 1.5bar. But the automatic transmission car does not exceed 3000 rpm. Same in neutral gear.
    Aug 2020
    Quote Originally Posted by er41 View Post
    Got a 1.9 passat for half price because of same oring on turbo hose. Smokey and low power sorted after replacement but the giveaway was the spray of oil in the same area
    HaynesPro 2025 online + AC/ Delphi 2022.02a available, message for where to get them!
  10. #9
    57Tuning's Avatar
    Dec 2023
    Romania
    SW: 6576286144
    so actually on car loaded mod is, just egr off? or what you did with ecu? because you loaded "ori" up
  11. #10
    Jul 2016
    Currently the ori file is loaded in the ecu. I tried egr off, swirl flap off, tva off file and there was no change. I also tried the MAF sensor. I also tried straight pipe.
  12. #11
    Jul 2016
    Is the file I am reading original? Can someone check it?
  13. #12
    May 2017
    looks in several maps ... looks stock
  14. The Following User Says Thank You to Lambda1 For This Useful Post:
    volodin69 (6th January, 2024)
  15. #13
    Nov 2017
    Dobruja
    Vacuum issue, waste gate issue, or turbo has ashes deposits. Like all of you already wrote here... Must be checked...
    I blame some vacuum leak, or turbo vacuumatic capsule screw.
  16. #14
    Jul 2016
    The problem is solved, they put oil in the tank, the car cannot turn over because the pump cannot draw.
  17. #15
    Dec 2024
    what was the problem?Something similar happens to my car and I haven't found the problem.
