Results 1 to 10 of 10
    Nov 2011
    Default VW GOLF 6 2011 - dash cloning possible ?
    VW GOLF from 2011
    eeprom and micro D70F3425GJ(A)
    Can this micro be full read ? is cloning possible for this dash ?
    Thx
    Sep 2021
    NA
    Quote Originally Posted by CARPARTS View Post
    VW GOLF from 2011
    Thx
    It should be, not a locked one at 2011, need same dash hw and copy the whole thing (app and all user data). Make sure to not plug another one in prior to clone or you will get in trouble )
    honingkoning's Avatar
    Dessert
    VW GOLF from 2011
    Thx
    First tell us your situation,is the dash alive etc etc.
    Best way is to use some good tools and read Immo block and swap this to new dash.
    And with vcds transfer coding and you are done.
    And before you mount the new dash save coding from abs with vcds.
    Wbr
    Sep 2021
    NA
    Quote Originally Posted by honingkoning View Post
    Wbr
    Immo alone is insufficient, it will trip component security, radio will not work etc, need full clone
    Maartinj's Avatar
    Nov 2010
    Quote Originally Posted by vov4ik View Post
    golf 6 not use Component Protection, definatelly not 2011
    copy immo + radio code and you can have full cluste clone
    Feb 2024
    Where is the IMMO part written? I want to clone my dash with MFD+ to MFD Premium. I can read and write different EEPROM chips. On the backsite of the pcb is a EEPROM called 24C64WQ. The IMMO block is not in it, right?
    Dessert
    Like maartin say no CP in golf 6 and radio is not hard to solve.
    You can buy your code from a broker.
    Dessert
    Quote Originally Posted by Maartinj View Post
    Can you share where radio code is stored in the dash.
    Usually i read code from radio with martech tool.
    Wbr Adam.
    Sep 2021
    NA
    In 24c64 0x1298-0x1299, when you change it and milage and immo you will have to recalculate crc too, so why not just overwrite everything with full read like I advised earlier?
    Sep 2012
    simple read old dash D70XX.. clone or write in the other dash and that it, use good tool nothing more and if there are a eeprom copy too, think is 2011 there is not much science
