Results 1 to 4 of 4
    Apr 2021
    Exclamation Yaris 2003 lost key...
    I have a problem with a 2005 Toyota Yaris I can't get it to start. I've done several before without problem. I produce the transponder with AVDI, (all the yaris I did before 2005 were all 4C) but no result, the security light still flashes
    I tested the coil it is ok. In doubt I even created a 4D transponder with effi but without result
    I am attaching the reading of L56R read 93c56 if you see anything abnormal. and also the dump made by avdi. I know someone came before me for this job
    Apr 2021
    me again, so I think the best for me would be a blank ecu file but the label is erased The engine code is 2SZ-FE DENSO calculator
    Apr 2022
    Germany
    I checked both files with few different programmers and both files are OK (93c56 + fvdi key 1).
    Both files are from engine CU... On both files are keys 1,2 and 4 used. The only empty position is key nr. 3 free.
  4. The Following User Says Thank You to wuza For This Useful Post:
    MACAN (22nd January, 2024)
    Apr 2021
    Yes it's that. Weid thing
