hi could anyone add aggressive hardcut limiter to this file please thanks
would anyone have a map pack for this file ? or explain changes needed to create a nice hardcut limiter please. thanks
Good morning,
so, it depends on how you want to do the hardcut, there are several limiters on this ecu where you have to act, if you want it soft, if you want it hard, if you want it with smoke, if you have an automatic gearbox and you want it in parking, or in neutral, or while driving, if you want it in all possible ways, at what Rpm you want it... it's not like you can explain how to do it in a post.
B. Regards
File service, Custom Remapping, stage 1 & 2 dyno tested.
Petrol + Diesel
Adblue dpf egr Only tested working solutions.
Use thanks and Rep if my help was helpfull.
K1 autos (27th January, 2024)
OK thanks so be looking for a hard hardcut on neutral and while driving in gears dont mind a bit if smoke but preferably little smoke but I understand fuel is needed . Be looking for manual and auto solutions but this file ive attached above is a manual f30 320d. Thanks
