Results 1 to 5 of 5
Thread: Pug 208 P101D
    May 2010
    Default Pug 208 P101D
    Dear Peugeot experts,
    Peugeot 208 petrol = benzin 1397 displacement 70kW engine code 8FS, year 2009
    after head rebuild has DTC P101D open circuit VTI electric motor
    On VTI connector there are 2.77 V between the 2 pin with the connector disconnected.
    Does the VTI motor need some settings or regulation after head removal?
    It currently lack of power or die on the road.
    ______
    Meat-Head's Avatar
    Put a 501 bulb across it. Sidelight bulb
  3. The Following User Says Thank You to Meat-Head For This Useful Post:
    alessioblaupunkt (2nd February, 2024)
    May 2010
    The mechanic that fitted the head did the job on late evening.
    He checked in the morning the whole process and found loosen bolt on cam sensor.
    Now engine run ok he will delete DTC and run.
    ______
  5. The Following User Says Thank You to alessioblaupunkt For This Useful Post:
    Meat-Head (27th January, 2024)
  6. #4
    Meat-Head's Avatar
    Odd as often can unplug cam sensor and will still run
  7. #5
    May 2010
    In fact still having problem. Will try the 501. When winter go away.
    ______
