Results 1 to 4 of 4
    Col19's Avatar
    Jan 2019
    France
    Default Flash for UCH N2 X76
    Hi friends
    I wanted to add a Kangoo 4x4 key, and as luck would have it when I was learning the battery my battery died, so the warnings stay on permanently and I no longer have communication with uch.
    UCH-N2-X76 / P8200094768
    I had read the eeprom before launching so normally it is intact, I think the flash is stuck in boot mode. Is there a brother who has flash + pinout please, that would be a big help to me.
    Thank you in advance, Respect.
    Jan 2016
    Poland
    Did you disconnect the battery for about 10 minutes?
    It could have crashed. I don't think there's anything wrong with flash.
    (Sorry for my English).
  3. The Following User Says Thank You to patiomkin For This Useful Post:
    Col19 (6th February, 2025)
    Col19's Avatar
    Jan 2019
    France
    Thank you dear friend, I haven't tried it but I dismantled the module and put it on the bench and still no communication, I thought it was perhaps stuck in startup mode, no alarm, thank you again for your support, respect to you
    Jan 2016
    Poland
    Disconnecting only the UCH may not help. I repaired Renault Fluence and after calibrating the ECU, it stopped starting. Disconnecting the ECU power supply did not help. Only when I disconnected the battery did the engine start. Do you have Renolink? What microcontroller is soldered there?
