You need seeprog and upa
I'd like to read memory dumps from radio security chips.
I've looked at the TMS 370, also PonyProg (from what I've read it looks as if you need to build this yourself)
Just wondering what is recommended that would cover the widest range of chips used in coded radios, and if there is any programmers that can read chips in-circuit?
info and help greatly appreciated.
Thanks in advance
If you realy plan to work on this for living then recomend small seeprog for all eproms 24xx93xx95xx work perfect cheap as original from elnec..UPA usb also nice tool for all other..pony is child toy,but we alls tart with something like pony..about reading in circuits..ic chip is 8 pin desolder it will be much easier and safest for youre work..but IF you need to read some motorola with 68 pins..I will try all what I know to read it on board..even IF I need make some adapter board or interface...my vote is for seeprog best tool I ever buyed (10 or more years ago)..advice: search and buy some nice 8 pin smd/dil adapter for today electronic and working with seeprog
regards !
Carchima & Dimitar, thank you both for your valuable information. Already looking into this programmer. I'm approaching this interest in decoding from a hobyist point of view, and hope if I could earn some money through decoding a radio - it will finanace cost of equipment. I once worked for an auto-electrician and used the Joule system - but as I understand that's a very expensive system - but I'd like to learn more about what's behind that system through using a stand-alone programmer.
Cheers.
even this is yust hoby try to make it in profesional way,Iam not quite familiar with Joule system.but working with programer is easy..all you need is to identified chip where code is store,find tool able to read this chip,then compare youre dump with dump with known code.there is lot of calculators for code from dump.even if you cant calculate code from this dump there is always somebody who can ..yust put youre dump here and sombody will solve it..for few sets there is also calculator from serial number of radio..anyway good luck with new tools
regards!
seeprog and upa
hi lads
new to this eeprom stuff
i just got seeprog so what adaptor do i require to read 8 leg chips?
and where can i get it?
I recommended xeltek 580u
- seeprog (it's cheap, so buy original)
- upa-usb (it's cheap, so buy original)
- xprog-m (china), work perfect and cheap will cover also most motorola mcu
