Results 1 to 11 of 11
    Default Help!Need im*o free 95040 eeprom file ME7 LEON CUPRA R
    Hi i have a Leon Cupra R 225 2004 previously been revo'd. I have stock dump for psop44 which i have modded and put back on but now need to get rid of Revo coding in serial eeprom(95040) to make it run correctly.
    Does anyone have a im*o free 95040 serial eeprom file for this ecu?
    HW0261208221
    SW1037367220
    maaxxyy's Avatar
    North Pole
    What software/hardware are you using?
    Kessv2 and ECM titanium
    The problem is the revo coding in the serial eeprom which makes the car run in los after a mile or so.
    I came across the same problem on S3 but i cant find the file anywhere that i made and i dont have a original either!
    maaxxyy's Avatar
    North Pole
    I thought the revo problem was overcome by bench flashing? Unable to flash via eobd when revo installed...
    Hi yer it usually is with some Revo'ed vehicles but this one read ok (customer did not know vehicle was revo until after we read it) so we found a stock file and wrote through obd port which was fine but after a mile or so it losses power,apparently something todo with serial eeprom coding.
    Ive desoldered psop 44 and done it that way but still the same.
    DK Veteran aminebot's Avatar
    Oct 2008
    Algiers
    Quote Originally Posted by Optimum Tuning View Post
    HW0261208221
    SW1037367220
    what is the VAG reference ?
    kevfield's Avatar
    uk
    Try and report
    Good stuff, thanks
    hi thanks for file but car doesnt start with it
    UK south
    Dont Know if you still need a 95040 file try this
