Good day, can someone change mileage on holden captive 2016 current odo around 220k km someone please change to 178k
Give this a go and post the result.
BeachBoy42 (9th February, 2024)
This from the cluster or BCM?
AFAIK, the cluster grabs its odometer data from the BCM generally located in the passenger kick panel. Black box and inside there is the same chip.
Cheers
Hey! ok will try to read data from BCM. So is it only enough to do BCM?
or i have do BCM and dash also ?
only bcm there is stored the km
Got bcm out and do read out on 93a66, can someone do 178k
you had read it by 16? or 8?
i think the km is in the dash
hmm, maybe i read it wrong. Will try to read with different eeprom type
The mileage is in the dash, write the file I posted.
BeachBoy42 (15th February, 2024)
yes, clusters that he said is correct
Yes you are right, writed your file and it worked! Thanks again
