Results 1 to 15 of 15
    S0nda's Avatar
    Nov 2021
    Reading....
    Default opel astra h CD30 radio code
    hello
    i'm having a problem with astra h radio replaced.. now i'm getting on display SAFE.. i have read eeprom can someone find me pin?
    CD 30 RADIO!
    thanks.
    Autotuner Master - FLEX Master - DFOX Master (DFBtechnology) PCMflash 1.3.8 - VCDS hex v2 - Scanmatik 2 pro - Launch - Odis
    "clones" -> Ktag - Kess v2 - Mpps v22 - FGtech - Inpa -
    WinOLS 5
    IF helped! Press "Rep & Thanks"!
    WALES
    Quote Originally Posted by S0nda View Post
    hello
    CD 30 RADIO!
    thanks.
    What happened to original radio? can you post it's dump?
    wbr
    S0nda's Avatar
    Nov 2021
    Reading....
    Its already replaced by someone else and dont have it.
    WinOLS 5
    WALES
    Ok, then you will need to post dump from Car's Display for pairing PIN (93C56 8bit)
    wbr
    NB: Here is your radio set to virgin, ready for pairing
  5. The Following User Says Thank You to shooting For This Useful Post:
    S0nda (8th February, 2024)
    S0nda's Avatar
    Nov 2021
    Reading....
    Quote Originally Posted by shooting View Post
    wbr
    Thanks for virgine the file
    But i also need it's pin.. for ori eeprom
    WinOLS 5
    WALES
    Read Post#4 again!! you need Display dump for PIN....
    wbr
    S0nda's Avatar
    Nov 2021
    Reading....
    wbr
    I have read display pin with FVDI, now i have to update virgin dump on radio and it will work? Or any other special procedure i have to follow?
    Thanks.
    WinOLS 5
    WALES
    Thanks.
    Just add radio and pair (Activate security) & use PIN from Display (Not Cluster)
    wbr
  10. The Following User Says Thank You to shooting For This Useful Post:
    S0nda (18th February, 2024)
  11. #9
    S0nda's Avatar
    Nov 2021
    Reading....
    wbr
    Thats what i tried today but didnt worked
    On radio i used to "activate anti theft security" used PIN from display (message was successfully) but still keeps radio safe
    Tomorrow will try ur virgin dump and re try
    WinOLS 5
  12. #10
    WALES
    It will only work with my virgin dump from Post#4
    wbr
  13. The Following User Says Thank You to shooting For This Useful Post:
    S0nda (19th February, 2024)
  14. #11
    S0nda's Avatar
    Nov 2021
    Reading....
    wbr
    I did today..
    Now no radio safe.. reading cd's and everything
    Just there is no AUDIO sound at all, cant find the issue if its still about coding
    Or any wiring issue
    Thnx
    WinOLS 5
  15. #12
    WALES
    I did today..
    Or any wiring issue
    Thnx
    Which OBD2 tool are you trying to pair with?
    wbr
  16. #13
    S0nda's Avatar
    Nov 2021
    Reading....
    wbr
    Tried with op com and fvdi.
    Radio hasnt "safe" anymore, when i put cd it reads and move secs.. but no sound
    WinOLS 5
  17. #14
    WALES
    You have another problem
    wbr
  18. #15
    S0nda's Avatar
    Nov 2021
    Reading....
    wbr
    first time working on thess probs..
    WinOLS 5
