Page 3 of 6 FirstFirst 123456 LastLast
Results 31 to 45 of 81
  1. #31
    cool.
    if i buy a new immo chip and put this into my used RCL keyfob, plug it into PP2000 and do the key learning - do you reckon the RCL will now work with this keyfob?
    i.e., my current immo chip from my spare key comes from a non RCL keyfob.
    or do i need a new RCL fob with a new immo chip?
    cheers
  2. #32
    Quote Originally Posted by seeyoujimmy View Post
    cool.
    if i buy a new im*o chip and put this into my used RCL keyfob, plug it into PP2000 and do the key learning - do you reckon the RCL will now work with this keyfob?
    NO if its a standard blank one, IT HAS to be one for a remote keyfob as these have different data in them to a non remote imobilliser chip, i am now trying to find somewhere that sells 'blank' imobilliser chips that work with remote keys
    i.e., my current im*o chip from my spare key comes from a non RCL keyfob.
    NO DEFINATELT THAT WONT WORK
    or do i need a new RCL fob with a new im*o chip?
    YES that at the moment is the best option, if you want to pm me with your vin number i can tell you which remote key you need as there are different versions of them too!
    cheers[/QUOTE]
  3. #33
    hey
    i need keyfob 6554.YL, i found that on service box a while back.
    if you find anywhere that sells the pre-coded remote immo chips then that'd be great to know.
    thanks for posting your findings.
  4. #34
    hey
    if you find anywhere that sells the pre-coded remote im*o chips then that'd be great to know.
    cheapest i can find if your in the UK is this
    Hickleys :: Find the Key you Need
    and then type in 6554yl
    its the complete unit at ?29.13 plus vat and post, but cheaper than peugeot at ?52.62 plus vat!
    still looking for the immobiliser chip precoded
  5. #35
    how much was the total cost for your new key?
  6. #36
    mine (HVRM69)was ?29.13, i ordered 2 so that was ?58.26 , then there was postage of ?5.95 then the VAT
    so my 2 keys come to ?75.45 delivered
    yours (HVRM70) from them will be ?29.13 plus ?5.95, then plus VAT
    so thats ?41.21 total delivered
    Peugeot price for your key ?52.62 plus VAT = ?61.83 and you have to pick it up yourself at a peugeot garage
    hope that helps
    cheers
    Andrew
  7. #37
    thanks, andrew.
    i got the prices for the key but couldn't find a postage cost without signing up to the site.
    will do this at some point before i sell my PP2000.
  8. #38
    I had some parts off them a year ago and they used to charge ?3.95 postage, but now it seems to have gone up to ?5.95, but still overall seems to be the cheapest i can find on the net
  9. #39
    Quote Originally Posted by andrew96 View Post
    S U C E S S ! ! ! !
    I was using standard im*obiliser chips i programmed the other day to the car before the remote fobs arrived. when the new remotes arrived i changed the im*obiliser chips for the ones i had already programmed and then using peugeot planet programmed them back to the car and the remotes would not syncronise.
    Tonight i looked at the new (unpaired) im*obliser chips that came in the remote keys... and SUPRISE they contained different data to the normal (unpaired) chip with no remote!
    so i then put the new im*obiliser chip that came with the remote fob back into the remote fob, used planet to pair (and lock) the im*obiliser chip to the car, then right after did the remote pairing sequence, waited 30 seconds and pressed the lock key! IT WORKED!!!! i now have a remote key paired!
    boy i am happy! taken all day but it works!
    I am in your same situation have both 73373067B and 73373067C and I think I mixed them all up when changing into the fob. I think I have right one in fob as I dont have engine immobolizer fault showing on display screen. But I cant seem to lock or unlock the doors with remote or program them even though the code for immob is accepted by pp2000.
  10. #40
    hope that helps
    cheers
    Andrew
    Andrew
    I am about to order from hickley's but which one do I order for my car and whats the difference between them both (HVRM69 & HVRM70)?
    Vin is VF32DNFUR42857190
  11. #41
    london
    azaing info contained in this string of posts
  12. #42
    Member Foblas's Avatar
    Belarus
    hi all, i have a problem. My used peugeot 406 car goes without RCL card into key. I buy used RCL card from another 406new and try to learn it to auto but but nothing happened. RCL is radio.
    Is it possible to learn RCL card from another car to my? I wath remote lock/unlock doors function get works.
    Thanks in advice and sorry for my english ))
  13. #43
    is it an IR remote?
  14. #44
    Belarus
    Quote Originally Posted by jgy6000 View Post
    is it an IR remote?
    RCL is radio.
  15. #45
    B'ham
    Hi Andrew,
    I am in a similar position to Jimmy in that my 206 has one RCL key and one standard key, and both are fully functional with the car immobilizer. By reading through your findings I think the following procedure should work, but can you have a look to see if you think this will work?
    Firstly I will buy a 2nd had RCL key from ebay and discard the ID46 chip from it. I will temporarily transfer the ID46 chip from my working remote key and place into the ebay key and use this combination to program the RCL on the ebay key. Now I will put the ID46 from this ebay key back into the original remote key.
    Thus far I have my two original keys (one remote version and one plain version), and an ebay key with a correctly programmed remote but no ID46. So now I can transplant the ID46 from my plain key and put into the ebay key.
    The ebay key now has a valid remote, but the transponder that is inside it is one without the RCL coding. Do you think this key will be OK in normal use without causing any issues when trying to start the car? I would imagine the car would just think it has been started with a non-remote key but would this cause any problems?
    cheers
    [/QUOTE]
