Original have separate transponder but on kd need choose nb series 206cc
Στάλθηκε από το F3311 μου χρησιμοποιώντας Tapatalk
rob h (26th February, 2018)
The remote with one button it supposed work on older 206 before 2001 but Ufcorce not work because also need married transponder
You need this
rob h (9th March, 2018)
I programmed the keydiy key today.
Remote worked instant, after programming this key.
This 206cc came with ne73, in menu pictured with va2.
You try synchronize remote? This remote work on this car i have use it. Photo is wrong.
There a 2 PSA 206 options.
The one va2 in your picture, worked.
The one with the Ne73 blade did not.
So your picture is the correct menu choice for this car.
I programmed the pcb transponder, pulled out key.
Then pressed a button, and the remote simply worked.
No special synch proces needed.
I used the vvdi2, with xhorse keys, which works same as keydiy.
Perfect, thank you for your help,
kleidaras (9th March, 2018)
