Results 16 to 30 of 34
  1. #16
    london
    can somebody post the information that was used to precode so that we can see it. yes we know that all cars are different on the precode but this is very confusing. so if we could see this it wld help. also what is the correct sequence for adding a blank fiat key from china with a id48 inside?
  2. #17
    OK friend that system type and this bsi that you wants to program ? bsi Delphi or marelli ? one and thing and correct if the chip not has precod you not manages to work that car. now if you use the chip that stopped to working in this car that you is program he comes back to work in this same car and alone you program him again.
  3. #18
    Quote Originally Posted by rayjay View Post
    You need to read the eprom, to precode the transpnder you need something like zed-bull to do it from the eprom dump, then you can program the transponder into the car using a sbb etc
  4. #19
    london
    paul reading your posts you dont know how to precode as you are getting errors.
    can we see the dump and precode?
  5. #20
    Top Poster djorgensen's Avatar
    Cardiff, UK
    I have the same problem
    I have a dump and got the pin code from ICC, but each time I try and program a transponder (from another fiat) in, it reports aquisition failed authentication failed
    If I need to get some blank ID48's wheres the best place to get them?
    Tar
  6. #21
    Quote Originally Posted by ajatochaveiro View Post
    fala ai chaveiro ajato , meu msn e dam495495@hotmail.com
    adiciona ai no caso de ambos termos duvida a respeito de um servi?o ou outro em rela?ao a chaves codificadas, blz
  7. #22
    Cardiff, UK
    Would something like work?
    HONDA ID 48 Transponder Chip(including 10 pcs)
  8. #23
    Junior Member Rodent's Avatar
    Nov 2010
    UK
    To clarify..
    If you have the dump from a Fiat BSI then with genuine equipment you can:
    Pull the pin code
    Precode a blank ID48 transponder
    Program this transponder to the BSI along with any other existing keys from that vehicle
    You cannot unlock a Fiat ID48 transponder so throw it in the bin or find another and make a pair of earrings for the wife, cheap Christmas present but she won't know what they are used for really!
    With cloned equipment you may or may not be able to do the above - you pays yer money and you takes yer chance......you can still make the earrings though.
    Whatever kit you use - remember to wait for 15 minutes after reinstalling the BSI and reconnecting the battery before trying to program or it may fail regardless of what equipment you are using.
  9. #24
    Cardiff, UK
    When I tried to get a blank ID48 from Hickleys they told me it wont work on a Fiat.
    What I dont understand is what is a blank ID48, i.e. why are some sold as Honda ID48s and VW ID48s, etc
  10. #25
    Quote Originally Posted by djorgensen View Post
    precoded to work for them vehicles, you need a true blank id48
  11. #26
    Nov 2010
    UK
    Basically if you get normal T6/ID48 virgin transponders from any source they will work on Fiats but you MUST precode the chip first.
    Just make sure you get T6 and not VAG CAN ID48s they definitely won't work.
    I have bought them from Hickleys many times so maybe you should just ask them for T6/ID48s that you are going to precode for a FIat and they will understand what you need.
  12. #27
    Apr 2013
    United Kingdom
    vag can is glass transponder. fiat id48 is ceramic
  13. #28
    Quote Originally Posted by urcarpc View Post
    Most fiat keys only come with round holes for id48 glass transponders
  14. #29
    Apr 2013
    United Kingdom
    Quote Originally Posted by paul_12345 View Post
    Yes u can have both ceramic and glass. Im working on a punto now, im going to test a magic I & II id48 on it and see if I can code it
    Sent from my GT-I9100 using Tapatalk 2
    Hit like and thanks if I've helped you!!
  15. #30
    EU
    most fiat and iveco is ID48 glass chip , made many times , read dump from bsi , whit effi or original zed bull , precode the transponder and whit calculated pin program transponder to car,whit sbb t300 etc.. if you don`t have obd diagnostics use key to dump, write it to memory device and you are ready to start the car .
  16. The Following User Says Thank You to iozo For This Useful Post:
    urcarpc (4th July, 2013)
