Results 1 to 15 of 19
    levisdj's Avatar
    EcuLand
    Default Sid 306 eeprom crc calculation
    Hi, please help with eeprom crc calculation after mileage mod in dump. Never had a issue with bosch ecus but siemens seems that my tools don't support. Attached org and mod, thanks!
    Feb 2020
    Ukraina
    what mileage is needed, I'll try to change it in the original
    levisdj's Avatar
    EcuLand
    199018 is shown onto the odometer
    Had read with Xtool 448924, 448906 and 357490
    Feb 2020
    Ukraina
    pass pm...............
  5. The Following User Says Thank You to fww1 For This Useful Post:
    levisdj (12th February, 2024)
    eliet2000's Avatar
    Sep 2011
    Pixa-Roglet / Valencia / Spain
    Original = 448906 km ?
    Mod = 199.018 km ?
    Algoritm = CRC-16/X-25 in VIN block
    55553148534441434E3435373031323131B9F2 CRC-16/X-25 in swap bit
    Pepelno Vds Pro
    Mangarrufa Power Solutions
    thank you is free
  7. The Following User Says Thank You to eliet2000 For This Useful Post:
  8. #6
    levisdj's Avatar
    EcuLand
    fww1, thanks for your effort, but it seems that your mod wiped out the whole eeprom.
    @eliet2000 would you be nice enough to give an example ? the values are good, but it's the other way around
  9. #7
    levisdj's Avatar
    EcuLand
    I'm sorry, I did a few tests with the example above, but there's a no go. Can someone help calculate the crc in eep v2 please? Thanks
  10. #8
    Feb 2020
    Ukraina
    what is the error when writing the mod?when editing eeprom control does not change
  11. #9
    levisdj's Avatar
    EcuLand
    Car starts and runs rough with alot of smoke! 100% crc error as I had a few megane in the past with sid307... so need correct crc calculation
  12. #10
    Feb 2020
    Ukraina
    when editing eeprom CRC does not change
  13. #11
    Feb 2020
    Ukraina
    try to record the original eeprom, see how the car behaves
  14. #12
    levisdj's Avatar
    EcuLand
    As stated, normal no smoke, runs as its supposed to....
  15. #13
    MartiLer's Avatar
    Dec 2016
    I can manually calculate the checksums in the eeprom dump if this is still relevant.
  16. #14
    levisdj's Avatar
    EcuLand
    Yes friend, still need!
  17. #15
    eliet2000's Avatar
    Sep 2011
    Your corrected file, regards.
    Pepelno Vds Pro
    thank you is free
