Results 1 to 7 of 7
    Jan 2020
    Default How to delete DTC from ecu
    Hey guys,
    I am trying to learn about deleting fault codes DTC from ecu manually way. I saw the videos from VAGECUMAP but I am with some doubts how to identify which data are ambient conditions, which data are counters etc. I tried to delete some DTC from a edc15c6 ecu from a w210 mercedes but I cannot identify data.
    I am also trying to download some files from the forum originals that have a version with deleted DTC so I can compare them and try to learn how they did the solution. But the problem with that is that most of the files have password and the users did not answer to my message asking for password.
    Can Someone help me how to delete DTCs from ECUs manually? Some videos or pdfs or some info to learn how I can delete DTCs from ecus mostly diesel.
    Thank You very much for Your attention.
    Have nice day
    Feb 2024
    Hi tigo3ano
    I will uploaded a exemple original file and file dtc removed to compare and find a table DTC error's.
    Feb 2024
    Hi.
    I add a exemple on EDC15 for table dtc ...
    Have Original file and mod file..
  4. The Following 2 Users Say Thank You to MMTDI For This Useful Post:
    nicocr (21st March, 2024), tigo3ano (28th February, 2024)
    Feb 2024
    File don't have password
    Jan 2020
    Thank You very much I will study the file.
    Feb 2024
    Mar 2024
    Bulgaria
    Use xdecoder and campare file will be easy but evry ecu is deferent...
