Results 1 to 5 of 5
    rob h's Avatar
    May 2011
    Default Peugeot Partner JCI bsi, how to read flash in circuit.
    SPC560B60L7 + 95128
    981218948002
    BSI04EV2 KE3-00 230316
    Hello guys,
    I have been given a bsi.
    No communication in the car, or on bench.
    I have seen some read it with vvdiprog.
    Could someone show me the best solder spots?
    I found this
    79037942_470009093718616_6078517890900819968_n.thumb.jpg.38792f260579010ef74ac9be2845e0d4.jpg
    If not, i will figure it out.
    And share,
    rob h's Avatar
    May 2011
    78246490_470008993718626_7922739503062581248_n.jpgGoogle provides, again!
    [2024-02-23 22:35:37] : Initialization success!
    [2024-02-23 22:35:38] : Initialization chip...
    [2024-02-23 22:35:40] : ID FFFFFFFF00000000
    It does read, when aksed.
    But the s-flash does not look ok.
    rob h's Avatar
    May 2011
    https://www.digital-kaos.co.uk/forum...st-spc560b60l7
    So, i am not the only person failing to read,
    I will try, with adjusted vcc later.
    ricked's Avatar
    Apr 2016
    Europe
    if you do this work often i suggest you to buy IO terminal with psa license, this way you can extract via CAN line the software
  5. The Following User Says Thank You to ricked For This Useful Post:
    rob h (24th February, 2024)
    rob h's Avatar
    May 2011
    i have io.
    Like i wrote, this bsi, does not communicated anymore.
    So the only way to recover,might be with a prog.
    I upped the vcc step by step, all the way up to 5.0v
    0x418510FFFFFFFF00000000
    I have found similar bad readings.
    And some good.
    I like to believe, it can be done, with a programmer, but not by me today.
    Screenshot_20231210_160008_One UI Home.jpgcg100
